System: Host: skookum Kernel: 4.15.0-38-generic x86_64 bits: 64 Console: tty 0 Distro: Ubuntu 18.04.1 LTS
Machine: Device: desktop System: Dell product: Inspiron 620 v: 00 serial: N/A
Mobo: Dell model: 0GDG8Y v: A00 serial: N/A BIOS: Dell v: A04 date: 11/21/2011
CPU: Dual core Intel Core i3-2120 (-MT-MCP-) cache: 3072 KB
clock speeds: max: 3300 MHz 1: 1596 MHz 2: 1596 MHz 3: 1596 MHz 4: 1596 MHz
Graphics: Card: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
Display Server: N/A driver: i915 tty size: 158x63 Advanced Data: N/A out of X
Audio: Card Intel 6 Series/C200 Series Family High Definition Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.15.0-38-generic
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: d0:67:e5:2c:73:30
Drives: HDD Total Size: 2000.4GB (0.4% used)
ID-1: /dev/sda model: Hitachi_HUA72302 size: 2000.4GB
Partition: ID-1: / size: 1.8T used: 7.6G (1%) fs: ext4 dev: /dev/sda2
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 26.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 162 Uptime: 32 min Memory: 827.6/7889.6MB Init: systemd runlevel: 5
Client: Shell (bash) inxi: 2.3.56
error in syslog "no RTSP sources Found", also when using a2enmod cgi, at first it said no cgi conf found, now it says its enabled, but rtsp will not work.
http works and the rtsp feeds work in vlc.
i know inxi says its Desktop, but its ubuntu Server 18.04
Zoneminder 132.2
also found this in apache2 error log
[php7:notice] [pid 1721] [client 192.168.0.32:47192] PHP Notice: Undefined index: Type in /usr/share/zoneminder/www/includes/actions.php on line 620, referer: http://192.168.0.38/zm/index.php
Name "ZoneMinder::ONVIF::verbose" used only once: possible typo at /usr/bin/zmonvif-probe.pl line 81
Broadcast Message for journald@xxxxxx (Mon 2018-11-12 22:46:33 PST) zmc 5122: WAR zmc_m5 Sequence in probation 2, out of sequence
Thanks to this info, https://zoneminder.readthedocs.io/en/la ... tml#remote I worked around it, instead of setting remote method to rtsp, set it to ffmpeg now it works, not a fix but at least its working.
