Page 1 of 1
Multi-Server configuration question
Posted: Wed Nov 21, 2018 8:37 pm
by tcg
When setting up a multi-server configuration, is it necessary to reverse-proxy ALL ZoneMinder servers so that they can be accessed remotely? I was reading this thread:
viewtopic.php?f=36&t=27112
and it appears that I have the same problem as the original poster. I have a reverse-proxy set up to my primary server 'zm1'. However, I was under the (apparently mistaken) impression that that one server was all that needed to be exposed to the Internet and that it acted as kind of a gateway to the others. However, since URLs are generated using the hostname values defined in Options -> Servers it appears I will need to reverse-proxy my 'zm2' server as well. Otherwise I do not seem to be able to view video.
Am I on the right track here?
Re: Multi-Server configuration question
Posted: Thu Nov 22, 2018 12:25 am
by iconnor
For live view, you need to be able to hit the recording server.
So yes, you need to reverse proxy ALL recording servers.
