VersionController could not be found? Fixing API
maxiedaniels
Post by maxiedaniels »
When I go to http://myserver/zm/api/version.php, I get this:
Missing Controller
Error: VersionController could not be found.
Error: Create the class VersionController below in file: app/Controller/VersionController.php
I'm using 1.32, on Ubuntu 18.04.
Re: VersionController could not be found? Fixing API
That error does not mean the api is broken. I tested ZmNinja just the other day on Bionic/1.32.2 and it worked very well thank you...
you are calling the API function getVersion????
the URL should read :
http://myserver/zm/api/host/getVersion.json
maxiedaniels
rockedge wrote: Thu Nov 29, 2018 2:25 am you are calling the API function getVersion????
WHOOPS. Okay, phew. Wow so it's all working! Thank you!!
