Page 1 of 1
Getting err Bogus number of lines returned error
Posted: Fri Jan 04, 2019 12:42 am
by asantaga
Zoneminder 1.32.3, running within a docker container.
Hey all,
Im getting this error below repeated every 5-10 seconds and I cant figure it out.. I have no monitor 5 , nothing in the DB and its a fresh install..
Any ideas???
019-01-04 00:40:19	zms_m5		383	ERR	Bogus number of lines return from query, 0 returned for query SELECT Id, Name, ServerId, StorageId, Type, Function+0, Enabled, LinkedMonitors, AnalysisFPSLimit, AnalysisUpdateDelay, MaxFPS, AlarmMaxFPS,Device, Channel, Format, V4LMultiBuffer, V4LCapturesPerFrame, Protocol, Method, Options, User, Pass, Host, Port, Path, Width, Height, Colours, Palette, Orientation+0, Deinterlacing, RTSPDescribe, SaveJPEGs, VideoWriter, EncoderParameters, RecordAudio, Brightness, Contrast, Hue, Colour, EventPrefix, LabelFormat, LabelX, LabelY, LabelSize,ImageBufferCount, WarmupCount, PreEventCount, PostEventCount, StreamReplayBuffer, AlarmFrameCount, SectionLength, FrameSkip, MotionFrameSkip, FPSReportInterval, RefBlendPerc, AlarmRefBlendPerc, TrackMotion, Exif, SignalCheckPoints, SignalCheckColour FROM Monitors WHERE Id=5.	zm_db.cpp	129
2019-01-04 00:40:19	zms_m5		383	ERR	Can't use query result:	zm_monitor.cpp	2331
2019-01-04 00:40:19	zms_m5		383	ERR	Unable to load monitor id 5 for streaming	zm_stream.cpp	44
2019-01-04 00:40:19	zms_m5		383	ERR	Unable to connect to zmc process for monitor 5	zms.cpp
Re: Getting err Bogus number of lines returned error
Posted: Fri Jan 04, 2019 2:25 am
by bbunge
If you ever deleted a monitor and created another yes, you could have a monitor 5.
Posted: Fri Jan 04, 2019 8:47 pm
by asantaga
No , its a clean install. I even checked the monitor table in the DB and there isn't a monitor #5 ...
I'll check other tables
Posted: Fri Jan 04, 2019 11:29 pm
by asantaga
sussed it! and its not a bug with ZM.
I have HomeAssistant, which was polling Zoneminder's cameras. HomeAssistant hasnt been rebooted for a long time and it appears it was issueing web calls to view monitors on zoneminder. The issue here is that yesterday I rebuilt my zoneminder docker image and did a clean install and voila the monitor Ids changed :-)
All good thanks
