zmupdate: ERR [Error check failed: '404 Not Found']
dlandon
Post by dlandon »
I'm now getting this in the log every hour:
Jan 5 07:37:08 091cbfcabc15 zmupdate[750]: ERR [Error check failed: '404 Not Found']
I'm using Zoneminder 1.32.3 and zmeventnotification 2.5. Can someone point me in the right direction to find this error?
Re: zmupdate: ERR [Error check failed: '404 Not Found']
It appears that our server that lists the latest version not working.
You can remove the error by unchecking Options -> Check For Updates
dlandon
Post by dlandon »
Thank you.
dlandon
Post by dlandon »
Wouldn't once a day be sufficient for the update check, rather than every hour?
