Page 1 of 1
Issues post upgrade
Posted: Mon Jan 14, 2019 8:32 pm
by rebootln
Hello - i upgraded to 1.32.3 and it broke all the cameras
/var/log/messages shows
Jan 14 12:29:29 zmvideo zmc_m13[124940]: ERR [zmc_m13] [Unexpected response code 401, text is 'Unauthorized']
Jan 14 12:29:29 zmvideo zmc_m13[124940]: INF [zmc_m13] [Starting Capture version 1.32.3]
Jan 14 12:29:39 zmvideo zmc_m13[124940]: FAT [zmc_m13] [No RTSP sources]
The configuration of the camera itself is no different
Seems RTPS authentication is broken?
Any one else having this issue
System is
CentOS Linux release 7.6.1810 (Core)
rpm -qa | grep zoneminder
zoneminder-httpd-1.32.3-1.el7.x86_64
zoneminder-common-1.32.3-1.el7.x86_64
zoneminder-1.32.3-1.el7.x86_64
Any ideas ? I can post more logs if needed - Thanks!
Re: Issues post upgrade
Posted: Tue Jan 15, 2019 1:27 am
by rebootln
little more information here
So i have managed to get the camera working by allowing anonymous video stream and removing authentication user and password from the url and providing ip only
also had to change rtsp to http only
This is not a solution but a temporary workaround - we definitely don't want anonymous camera access
Any clues as to why rtps is broken
Posted: Wed Jan 16, 2019 2:51 am
by rebootln
hey guys - so i did a clean install in a VM on a fedora 29 - to try different things out - and i am getting the same issue
Cannot authenticate to RTSP or cannot use codec - depending on which method is selected.
Ideas anyone ?
Jan 15 18:46:18 localhost zmc_m1[47066]: FAT [zmc_m1] [Unable to locate video stream]
Jan 15 18:46:18 localhost zmdc[45898]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jan 15 18:46:23 localhost zmdc[45898]: INF [Starting pending process, zmc -m 1]
Jan 15 18:46:23 localhost zmdc[47068]: INF ['zmc -m 1' started at 19/01/15 18:46:23]
Jan 15 18:46:23 localhost zmdc[45898]: INF ['zmc -m 1' starting at 19/01/15 18:46:23, pid = 47068]
Jan 15 18:46:23 localhost zmc_m1[47068]: INF [zmc_m1] [Starting Capture version 1.32.3]
Jan 15 18:46:24 localhost zmc_m1[47068]: WAR [zmc_m1] [The device is using a codec that may not be supported. Do not be surprised if things don 't work.]
