packing ZM-1.33.x for a Slackware
Posted: Fri Jan 18, 2019 8:54 am
Hi!
I'm testing/using a ZM on a Slackware Linux.
Everything working fine until ZM GIT source somewhere after 6. 1. 2019.
ZM-GIT compiled after that day the application do not work - can not start Zoneminder from GUI (Run State change).
In a logs is a line:
zm-1.33.x GIT sources compiled and working OK for the following dates:
25. 12. 2018 - database 1.33.0
6. 1. 2019 - database 1.33.1 (the last until now)
failed GIT compiled ZM (both with above error described)
16. 1. 2019 - database 1.33.1
17. 1. 2019 - database 1.33.1
So the last working GIT I tested was at 6. 1. 2019
Suspecting you recently changed/added some dependencies, variables in configuration files, httpd/php config files, changes in SQL database etc.
Please write regarding changes that have been done since 6. 1. 2019.
If debug logs needed, I need some advice to set up ZM, default logs do not show any usable info.
Best regards to developers!
and I got empty camera cache file in /dev/shm:Got empty memory map file size 0, is the zmc process for this monitor running?
Tests performed with complete delete of all traces of zoneminder and fresh SQL database on every single test:-rw------- 1 apache apache 0 Jan 17 22:24 zm.mmap.1
