Hi Andrew, I tried too with the
18.04 and 16.04 images provided by Hardkernel.
I was succesful to build ZM from source and install the last
1.33.1 (and 1.32.3 too), but in this case, differently from Armbian image,
ffmpeg streams are not captured (the error messages are those I reported in previous post).
So, since 1.33.1 is working on ARMbian, the issue is related to images provided by Odroid. Probably you would be able to understand what to be adjusted on the Ubuntu images provided by Hardkernel, I'm not.
For experiment,
I built from souce a lower ZM versions 1.30.4 on xenial (16.04) image provided by Hardkernel.
Same issue:
ffmpeg not working and in ZM log same error messages as I posted previously.
So it seems an issue related to the Ubuntu images provided by Hardkernel:
https://wiki.odroid.com/odroid-xu4/os_i ... 4/20181203 (for 18.04)
https://wiki.odroid.com/odroid-xu4/os_i ... 4/20171213 (for 16.04)
The strange is ZM 1.29.0 is working fine with the 16.04 image provided by Hardkernel! So, something changed between 1.29 and 1.30 in the way ffmpeg streams are not working on ubuntu Hardkernel images.
Definitively I will use the Armbian 18.04 image that is working.
Andrew, please, since you have Odroid XU4, if you will have time, install ZM 1.33 package on 18.04 (or 16.04) provided by Hardkernel + LAMP and pls let me know what hell could be the issue (i.e.: why ffmpeg stream is not working).
Anyway, thanks, since I solved with the Armbian distro and I learnt how to build from source.
thanks
EDIT 2019 Feb 10: unfortunately also
Armbian has little issues, but for me important. On 1.33.1 and 1.32.3 both I'm not able to:
- view recorded MJPEG streams (i have a still image whatever selection for Save JPEGs in storage)
- save New (PTZ) Control (after pushing save button, the activity doesn't complete).
Probably the issues are simple to solve adiusting anything on ZM or Apache config file, or chowing anything or whatever hell needed (i passed all week end trying to adjust, no way). I tried but I'm not an expert.
I'm coming back to Ubuntu 16.04 image provided by Hardkernel and ZM 1.29 and Odroid XU4. All is working fine with such setup.
Probably due to different linux distros to be managed and the specific not so diffused ARM technology, the ZM tool is not still mature for newbie like me and good only for experts/developers. I understand the tool is not commercial and based on the good will of volunteers. 1.29 on Odroid XU4 and 1.30.4 on the older Radxa Pro are fully working and enough.
