Page 1 of 1
No live picture, no other pictures in web browser.
Posted: Tue Feb 19, 2019 7:19 pm
by mcll
Hi!
I had an older Zoneminder version running on my system without any problem (ZM v1.30.4.) but i made an upgrade to v1.32.3 as described. The new version wont start. Than i completely removed old ZM, and installed a fresh version. Now it's working, ZM recognises my cameras, settings are same as before. But i have no picture! I see a "broken" small icon everywhere where i could see my camera (live, recorded events, etc).
- zm001.JPG (36.29 KiB) Viewed 3133 times
I checked everything i found about this on the internet, everything seems to be ok.
Linux is Ubuntu server 14.04.3
Please help, my system is so unusable now.
Re: No live picture, no other pictures in web browser.
Posted: Wed Feb 20, 2019 1:38 am
by Pedulla
I couldn't get it to work on UB14 either.
Rebuild with UB18
Use these instructions:
https://wiki.zoneminder.com/Ubuntu_Serv ... _Bionic.21
Posted: Wed Feb 20, 2019 9:18 am
by mcll
Thanks i tried it. Not helped. Now i cannot get back to the old working 1.30 version.. ZM seems to be working, but cannot access the web interface, don't know why. How todo a clean install from scratch again? I removed zm completely, purged, etc, but now when i make a fresh install i cannot open anymore the webinterface of zm. Totally messed up... Reinstalling linux is not an option, because the server has to be online and working (has a lot of other jobs all the day).
Posted: Wed Feb 20, 2019 9:45 am
by mcll
I added repo for 1.30.4 now, installed from scratch (before i dropped old ZM database in mysql). Now when i start web interface i get the following error:
SQL-ERR 'SQLSTATE[42S02]: Base table or view not found: 1146 Table 'zm.Servers' doesn't exist', statement was 'SELECT * FROM Servers ORDER BY Name'
I tried to update database, no luck, error still there:
# zmupdate.pl -f
Freshening configuration in database
Loading config from DB
Saving config to DB
How can i get working ZM on my system again?
Posted: Wed Feb 20, 2019 1:36 pm
by mcll
Ok i got it worked...
Totally removed old version, deleted mysql database, repos, etc
apt-get purge zoneminder
apt-get clean
apt-get update
apt-get autoremove zoneminder
etc
removed ALL folders for zoneminder
Added manually the repo:
### cat iconnor-zoneminder-1_30-trusty.list
deb http://ppa.launchpad.net/iconnor/zoneminder-1.30/ubuntu trusty main
# deb-src http://ppa.launchpad.net/iconnor/zoneminder-1.30/ubuntu trusty main
### cat iconnor-zoneminder-master-trusty.list
deb http://ppa.launchpad.net/iconnor/zoneminder-master/ubuntu trusty main
# deb-src http://ppa.launchpad.net/iconnor/zoneminder-master/ubuntu trusty main
After that installed zoneminder again (apt-get install zoneminder).
Also need to purge browser cache, otherwise you cannot accept the new privacy statement (without clearing cache, if you click to accept, the page will only reload).
So i have now a working Zoneminder on my Ubuntu 14.04.4 LTS 64bit system.
Zoneminder v1.33.2 is now working!
