[SOLVED]Offline mode
whois1230
Post by whois1230 »
Hello, I managed to configure Zoneminder 1.30.4 on my Debian 9.8 stable(stretch) laptop, using my USB Camera, and it works fine. It can work in Local with modect, but I can't seem to find information on wheter or not Zoneminder can work completely offline, like, for example Yawcam(a Windows motion detector) can. Any info on this would be greatly appreciated.
Re: Offline mode
Sure, just unplug the ethernet or turn off the WIFI. If you want to view the console use http://localhost/zm or http://127.0.0.1/zm
