I updated zoneminder from 1.31 to 1.32.3 zmninja stop working i get api access error in the app, but in zoneminder api is enabled and the config its the same as it was before.
What can it be?
Zmninja not working after zoneminder update to 1.32.3
Re: Zmninja not working after zoneminder update to 1.32.3
Start with this
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
thanks
yes i just check and when i do /zm/api/host/getVersion.json i get error response
Fatal error: Uncaught Error: Call to undefined function apc_fetch() in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php:91 Stack trace: #0 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(363): ApcEngine->read('myapp_cake_core...') #1 /usr/share/zoneminder/www/api/lib/Cake/I18n/I18n.php(235): Cache::read('cake_dev_en-ca', '_cake_core_') #2 /usr/share/zoneminder/www/api/lib/Cake/basics.php(636): I18n::translate('Cache engine "%...', NULL, 'cake_dev') #3 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(184): __d('cake_dev', 'Cache engine "%...', '_cake_core_') #4 /usr/share/zoneminder/www/api/lib/Cake/Cache/Cache.php(151): Cache::_buildEngine('_cake_core_') #5 /usr/share/zoneminder/www/api/app/Config/core.php(375): Cache::config('_cake_core_', Array) #6 /usr/share/zoneminder/www/api/lib/Cake/Core/Configure.php(72): include('/usr/share/zone...') #7 /usr/share/zoneminder/www/api/lib/Cake/bootstrap.php(442): Configure::bootstrap(true) #8 /usr/share/zoneminder/www/api/app/webroot/index.php(90): incl in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php on line 91
This would require you to fix the ZM APIs.
There are several threads in the ZM 1.32.x and 1.33.x forums that might help you.
ES docs
zmNinja docs
ES docs
zmNinja docs
