ImageBufferCount 20 is too small
Posted: Wed Mar 20, 2019 3:24 am
I just started getting this error after installing 1.33.4 on my ODROID-HC2 today. The remainder of the message says that the count needs to be at least 81 or decrease the time between keyframes. I had installed 1.33.3 yesterday, and I don't get that error when I run with that version. Unfortunately, I deleted the source code and that's why I grabbed another sd card and did another install. I was surprised when I saw the version was bumped over night. Anyway, I doubt that the camera is sending keyframes at a different rate than when I run with 1.33.3.
If I try to bump the buffers up to 90, then I get a slew of errors of the type: Shared data on initialised by capture daemon for monitor...
Is there something else I can try?
If you are wondering why I'm not using 1.32, it did not work for my configuration. I found this post: viewtopic.php?f=38&t=28052 which is the same issue I was having.
My configuration is: ODROID-HC2
Linux distribution: Armbian_5.75_Odroidxu4_Ubuntu_bionic_next_4.14.94
Camera: Lorex LNE4422B, h.264, 2688x1520, 20 fps
