Multi Server install with linked cameras
Posted: Wed Mar 20, 2019 1:32 pm
In my setup I have 4 ZM Servers running. My cameras are connected to a NVR unit that provides 2 streams per camera, 1 high res and the other low res. 3 of the ZM Servers take the high res feeds and the forth server has all of the low res feeds.
The setup works great and performs quite well. However I'm not able to use the linked camera function. For example, I have a camera that should the front of my garage. So that I can record in high res I tried to link the two streams as described in the documentation. Because the high res stream and low res streams are not on the same server the linked function doesn't work. Linking two low res cameras, that are on the same server, it works fine.
Does anyone else have a similar setup and managed to get the linked cameras working?
