Alarm frames missing/dropping
Szajkop
Post by Szajkop »
I have a small setup with a few cameras on a linux system on modect mode.
I configured the camera buffers like this: https://prntscr.com/n26you
The problem is that, when an alarm event occurs, i get a smooth recording before and after event but very shuttery when the actual event happened.
On the android application, i can see the captures, and clearly there is a big pause between alarm frames https://prnt.sc/n272dx
What is causing this, and how can i get a smooth capture at the alarm frames?
thanks
Re: Alarm frames missing/dropping
Linux distro and version?
Szajkop
Post by Szajkop »
bbunge wrote: Thu Mar 28, 2019 12:20 pm Linux distro and version?
Distributor ID: Debian
Description: Debian GNU/Linux 9.8 (stretch)
Release: 9.8
Codename: stretch
zoneminder version (2:1.30.4-dmo1+deb9u2).
I have never been 100% satisfied with Zoneminder on Debian 9. You can check the install procedures on the wiki to see if you missed anything.
Szajkop
Post by Szajkop »
bbunge wrote: Fri Mar 29, 2019 2:03 am I have never been 100% satisfied with Zoneminder on Debian 9. You can check the install procedures on the wiki to see if you missed anything.
I used the following resources to configure:
https://wiki.zoneminder.com/Debian_9_64 ... Zoneminder
https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
