i made a fresh install of zoneminder to a raspi 3 according to the wiki.
The only difference is,that i used the zoneminder package that comes with apt-get install zoneminder.
A minor differnce is that i am using a mariadb10 on another host and not locally.
None of the monitors work. All zmc process exit immediatly. Also when i run them manually.
I can successfully stream to disk using ffmpeg manually with the rtsp url of the cam.
There are no logs from the zmc processes, even when i raise the loglevel to max.
Any help appreciated.
