Linked monitors and Montage
Posted: Fri May 24, 2019 7:09 pm
I use a low-res-low-fps-detect linked to high-res-higher-fps-record design on my system(s).
Especially now with multi-port, I'd like to be able to use a group of the low-res monitors in montage for over-all area status/monitoring.
But, when a operator clicks the low-res monitor (for a better view) in the montage view, it actually opens the linked hi-res monitor.
The next level, of this request, would then be to specify a specific monitor or group to launch when the low-res monitor was clicked. I think both actions could be accomplished with a new "montage-lauch" field in each monitor description and relegate the linking to event triggering. If not filled in the default action would be to launch itself.
Launch might be the wrong word, but you get the idea.
