Configuration option gone - Ffmeg/RTP Unicast
RobLevine
Post by RobLevine »
So I recently upgraded to 1.32.3. I have some Foscam cameras that I used to connect to using:
Source Type: Ffmpeg
Remote method: RTP/Unicast
with the rtsp commands in the Source Path
But in the new version if I select
Source Type: Ffmeg
The Remote method drop down does NOT include the option RTP/Unicast
Tried a bunch of stuff but can't get the cams to work. One is FI8921w - the settings current here don't seem to work.
kitkat
Re: Configuration option gone - Ffmeg/RTP Unicast
Post by kitkat »
My cheap Chinese cameras use RTSP and they work for me on ZoneMinder 1.32.2 with:
Source Type: Ffmpeg
Method: TCP
Source Path: rtsp://ip.add.re.ss:port/
RobLevine
Post by RobLevine »
Where do you put user name & pass?
RobLevine
Post by RobLevine »
Got 'em working - thanks for the tip!
For source path:
rtsp://usr:pwd@ipaddr:port/videoMain
