Page 1 of 1
ZM on Fedora 30?
Posted: Thu May 30, 2019 12:36 pm
by kenworth
Is anyone successfully running ZM on Fedora 30? Would appreciate knowing before I attempt an upgrade. I'm currently on Fedora 28 running ZM 1.32.3-1.fc28.
Re: ZM on Fedora 30?
Posted: Wed Jun 05, 2019 11:07 am
by kenworth
Never got any replies so I bit the bullet and upgraded. Went perfectly fine and took about an hour. Zoneminder appears to be functioning perfectly and I haven't found any other problems at this point.
Posted: Thu Jul 11, 2019 3:50 pm
by liderbug
I'm in the same place - just spent an hr - you don't have... ok, now I do. you don't have... ok, now you don't have crud.
What steps did you do to get it running? Thanks
PS to ZM why isn't it in the fedora repo?
Posted: Tue Jul 16, 2019 6:46 pm
by kenworth
I just ran the standard upgrade from Fedora 28 to 30 process. I'm getting the packages from the rpmfusion-free repo:
zoneminder.x86_64 1.32.3-3.fc30 @rpmfusion-free
zoneminder-common.x86_64 1.32.3-3.fc30 @rpmfusion-free
zoneminder-httpd.x86_64 1.32.3-3.fc30 @rpmfusion-free
Post upgrade everything just worked.
Re: ZM on Fedora 30? STUCK ON 29
Posted: Tue Jul 23, 2019 11:31 pm
by apti
No Go here. upgrade from fedora 29 to fedora 30 fails because it can't find the zoneminder repo for fedora 30. I looked manually and it is not there. only up to 29 so looks like we have to wait until ZM puts up a repo for fedora 30.
