1.33.11~20190625221925-bionic Storageareas
FYI the above version and the version before showed the following error on upgrade, running zmupdate.pl fixed the issue
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install. Trying to recover:
Setting up zoneminder (1.33.11~20190625221925-bionic) ...
Detected db service is mariadb.service
mysqladmin: connect to server at 'localhost' failed
error: 'Plugin 'unix_socket' is not loaded'
Creating zm db
ERROR 1524 (HY000): Plugin 'unix_socket' is not loaded
cat: write error: Broken pipe
Error creating db.
dpkg: error processing package zoneminder (--configure):
installed zoneminder package post-installation script subprocess returned error exit status 1
zoneminder
Jimmy
Re: 1.33.11~20190625221925-bionic
Getting error when updating other linux pacakages
1.33.11~20190702124025-bionic storageareas
I seen this last update, purged zoneminder and reinstalled
still the same
Processing triggers for libc-bin (2.27-3ubuntu1) ...
zoneminder
Setting up zoneminder (1.33.11~20190702124025-bionic) ...
error: 'Access denied for user 'root'@'localhost' (using password: NO)'
Creating zm db
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Error creating db.
zoneminder
still the same
zoneminder
Creating zm db
Error creating db.
zoneminder
