Combine events
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
strav
Combine events
Post by strav »
Phil,
It would be great to be able to combine multiple events together into a single event.
-strav
zoneminder
Site Admin
Re: Combine events
Post by zoneminder »
Hi Steve,
This is a good suggestion and I'll see if I can add it for the next version. Obviously there will be gaps in the coverage which I assume you're aware of.
Cheers,
Phil,
wmoore
Re: Combine events
Post by wmoore »
Steve, Phil,
A timing feature that says if a new event begins on the same monitor within 'X' seconds it should be appended to the previous event would be nice, however even a manual method would be good.
Say an option on one of the event screens to set check marks on a number of events that could then be combined. It could even be set to be handled in the background like the image deletes. I would think this would be a simple copy operation combined with a db update???
BTW, Terrific work here Phil.
-WAM
