adding a second camera, impossible
dojo
Post by dojo »
problem : can only have 1 camera at a time.
when trying to add a camera, log shows that cannot prime, and keeps trying without success.
the first camera continues to be captured without problem.
Environment :
raspberrypi 3B+ with raspbian "buster"
zoneminder 1.32.3 "followed the steps from the wiki"
camera : 3 cams, brand: digoo, model: BB-m1
source used = ffmpeg
path = rtsp:user:password@ip:554/user=[user]_password=[password]_channel=1_stream=1.sdp?real_stream
ps: stream 1 yield a 640x360 signal , verified via ffprobe commands.
increased /dev/shm to 2G but is not used much (few percent).
options-storage changed to point at a 1T usb-drive for all events
Load steady at less than 1.00.
with the commands ffprobe .... i get sometimes the following message " [h264 @ 0x17adbe0] concealing 416 DC, 416 AC, 416 MV errors in P frame"
anyone can give me a pointer on what to check next ?
Re: adding a second camera, impossible
Um /dev/shm is a ram drive. It can't be larger than available ram....
dojo
Post by dojo »
thanks for the comments, will try to understand what it realy means by searching the net. Have alote to learn about Linux for sure :D
Baylink
Post by Baylink »
I note also that your URL is rtsp:user:password...
If that's not a typo, it must be rtsp://user:password...
Raam401
Post by Raam401 »
Thanks for doing that thread, I tried assembling a first camera set and it didn't really go as I planned... Plus, I'm trying to do something that'll allow me to watch over the one of these houses in Greece I'm planning to buy next year while I'm not there, so I'll definitely need a multiple camera network.
micha2109
Post by micha2109 »
i thought, i am the only one... i do have the same problem like OP (same error messages etc). It's weird because using the same setup (4 dahua ip-cams via rtsp) with Zoneminder 1.30.4 it just works fine. Using Zoneminder 1.32.3 I can use 1 rtsp at a time only.
