Hello
I try to get my new Camera to work with Zoneminder.
https://www.ebay.de/itm/5MP-Mini-PoE-IP ... SwDEBcEIg5
I have Zoneminder v1.30.4 installed
I make a second Monitor with
ffmpeg
Sourcepath: rtsp://xxxxx:xxxxx@192.168.xxx.xxx:554/1/h264major
Remote Methode UDP Multicast
Width: 2592
High: 1944
I use the Displaysize show in VLAN Player. In VLAN Player i see the Video of the Camera. In Zoneminder there is no video shown. I try other configurations, but no works.
My old Outdoor Camer with 640 x 320 pixels works well with Zoneminder
When i push the ONVIF Link in the Configuration Window a empty Window will be open. ONVIF is activated at the camera
When i open the Monitor i see no video and i get this errors in the Log
2019-07-23 08:46:50.317354 web_js 17451 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-651553s.sock ) failed: Connection refused - checkStreamForErrors() ?view=watch
2019-07-23 08:46:50.237008 web_php 17451 ERR socket_sendto( /var/run/zm/zms-651553s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2033
2019-07-23 08:46:40.740110 zms 17565 ERR Got signal 7 (Bus error), crashing zm_signal.cpp 50
2019-07-23 08:46:40.216720 web_js 17451 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-651553s.sock ) failed: Connection refused - checkStreamForErrors() ?view=watch
2019-07-23 08:46:40.148173 web_php 17451 ERR socket_sendto( /var/run/zm/zms-651553s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2033
2019-07-23 08:46:30.660633 zms 17564 ERR Got signal 7 (Bus error), crashing zm_signal.cpp 50
2019-07-23 08:46:30.145613 web_js 17451 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-651553s.sock ) failed: Connection refused - checkStreamForErrors() ?view=watch
2019-07-23 08:46:30.065314 web_php 17453 ERR socket_sendto( /var/run/zm/zms-651553s.sock ) failed: Connection refused /usr/share/zoneminder/www/includes/functions.php 2033
2019-07-23 08:46:23.442184 zms 17563 ERR Got signal 7 (Bus error), crashing zm_signal.cpp 50
can someone help me?
Best Regards
Werner
RTSP Stream will not work
Re: RTSP Stream will not work
Hi
i solve the issue. The Problem is the high resolution. With 1920 x 1080 its works.
When i find no cause for this i make a new thread
best regards
Werner
best regards
Werner
