Page 1 of 1
only 1 frame captured
Posted: Tue Jul 30, 2019 7:26 am
by Andi79
Hi.
I'm new in zoneminder and i have big problems with configuration. ZM should caputure on Mocord mode, unfortuanbly it fires 1 event per second and captures 1 frame for it. There is a mssage "Not Capturing", but thousands (motion?) events .
I have a IPC120 capera and use the sourctype ffmpeg and path http://192.168.150.30/snapshot.cgi?user=camera&pwd=XXX or snapshot.jpg[...]
Is this wrong? Why that many events?
Regards
Re: only 1 frame captured
Posted: Tue Jul 30, 2019 1:00 pm
by asker
That generally means your motion sensitivity is set too high. Every minor change is trigger an alarm. This article may help you get started.
