Upgrade and broke API
Posted: Mon Aug 05, 2019 8:20 pm
Hi guys,
been a while since I've posted but things have been running fine until I took the plunge and upgraded to 1.32.
Here's the thing everything still works fine when I access ZM using ZM ninja via wifi on the LAN side but when I try to access from the WAN side I get a bunch of errors in the ninja log
It says I'm authenticated ok but there's an API error.
I can access the ZM via a browser on the LAN and get all the correct json responses as per the FAQ
Here are a few of my Log errors:
status 3 error the internet connection appears to be offline - how can this be when it says I'm authenticated ?
/api/host/getversion.json? undefined - but when I access from the lan it is defined.
PM debug zmautologin: Inside auth-error broadcast
Any ideas as to what I've screwed up ?
I've tried deleting the app and re-install but just the same. I'm not logged in anywhere else (that I know of).
Regards Tim
Regards Tim
