Page 1 of 1
You don't have permission to access /cgi-bin/ on this server.
Posted: Fri Aug 09, 2019 8:06 am
by Darkyere
Hi all and ty for reading.
I am a new user of Zoneminder.
I use Raspbian Buster as OS and Zoneminder 1.32.3
I have the problem that i cant watch the stream for my camera.
It seems like being some sort of permission issue but i cant find any info about my case on the web.
When clicking the Camera name it opens a window but shows no picture/stream.
When right clicking where the image is supposed to be and choosing to open stream link in another window i get
Forbidden
Apache/2.4.38 (Raspbian) Server at 192.168.1.64 Port 80
Im not sure how to fix this and i cant find anything related to my case.
Ty for reading
Darkyere
Re: You don't have permission to access /cgi-bin/ on this server.
Posted: Fri Aug 09, 2019 2:08 pm
by Baylink
Generally, this has to do with the Apache config on the linux -- in your case, Raspbian -- server.
Exactly what's not happy depends on how Apache got installed; I think Raspbian has a package for it.
I'd try
# find / -name cgi-bin -print
to locate that directory, and then
# ls -ld $FULLPATHNAME
to see what the permissions actually are.
That's a start, anyways...
Posted: Mon Aug 12, 2019 1:34 pm
by Darkyere
Ty for the answer i appreciate it.
I have been busy helping my neighbor so sorry for responding so late.
I used
/usr/lib/zoneminder/cgi-bin
/usr/lib/cgi-bin
If im not mistaken taken from the configuration files the one in question is
Since it needs the zms file that is in that location
The permissions on that directory goes is
drwxr-xr-x 2 root root 4096 Jul 30 14:05 /usr/lib/zoneminder/cgi-bin
During the guide i followed i had to set permissions on certain directory's/files as following
chmod 740 /etc/zm/zm.conf
I tried setting that on both
/usr/lib/cgi-bin
But i still get permission issues.
Again ty and sry for responding so late since im helping out my neighboor and still dont know when i will be able to look at the forum again.
Posted: Mon Aug 12, 2019 2:54 pm
by rockedge
what does your apache /etc/apache2/configs-enabled/zoneminder.conf look like? (or /etc/apache2/configs-avialable/zoneminder.conf)
do you have the zoneminder.conf enabled?
Posted: Mon Aug 12, 2019 3:09 pm
by Darkyere
I seem to have mine located in
ls -lah /etc/apache2/conf-enabled
lrwxrwxrwx 1 root root   30 Jul 30 13:56 charset.conf -> ../conf-available/charset.conf
lrwxrwxrwx 1 root root   44 Jul 30 13:56 localized-error-pages.conf -> ../conf-available/localized-error-pages.conf
lrwxrwxrwx 1 root root   46 Jul 30 13:56 other-vhosts-access-log.conf -> ../conf-available/other-vhosts-access-log.conf
lrwxrwxrwx 1 root root   31 Jul 30 13:56 security.conf -> ../conf-available/security.conf
lrwxrwxrwx 1 root root   36 Jul 30 13:56 serve-cgi-bin.conf -> ../conf-available/serve-cgi-bin.conf
lrwxrwxrwx 1 root root   33 Jul 30 14:13 zoneminder.conf -> ../conf-available/zoneminder.conf
-rw-r--r-- 1 root root  858 Jul 30 14:24 zoneminder.sav
And the zoneminder.conf looks like this
# Remember to enable cgi mod and serve-cgi-bin.conf configuration
# a2enmod cgi
# a2enconf serve-cgi-bin.conf
Alias /zm/cache /var/cache/zoneminder
<Directory /var/cache/zoneminder>
    AllowOverride None
    Require all granted
</Directory>
#  php_flag register_globals off
  <IfModule mod_authz_core.c>
           Require all granted
  </IfModule>
</Directory>
ScriptAlias /cgi-bin "/usr/lib/zoneminder/cgi-bin"
    AllowOverride All
    Require all granted
</Directory>
   RewriteEngine on
   RewriteBase /zm/api
</Directory>
   RewriteEngine on
   RewriteRule ^$ webroot/ [L]
   RewriteBase /zm/api
</Directory>
    RewriteEngine On
    RewriteRule ^ index.php [L]
    RewriteBase /zm/api
</Directory>
Is this as it should be ?
I followed a tutorial that told to change that specific file.
I luckely enough saved the old file as zoneminder.sav and that one looks like
    AllowOverride All
    Require all granted
</Directory>
    Alias /zm/cache "/var/cache/zoneminder"
    <Directory "/var/cache/zoneminder">
        AllowOverride None
           # Apache 2.4
           Require all granted
        </IfModule>
    </Directory>
  <IfModule mod_dir.c>
    DirectoryIndex index.php
  </IfModule>
</Directory>
    AllowOverride All
</Directory>
The cgi-part seems to be the same except in
zoneminder.conf
and
zoneminder.sav
I partly followed a Raspbian Zoneminder tutorial and the wiki
https://wiki.zoneminder.com/Debian_10_B ... e_Easy_Way
If i add to zoneminder.conf
instead i get
The requested URL /cgi-bin was not found on this server.
Posted: Mon Aug 12, 2019 5:58 pm
by Baylink
I think the next thing you need to do is make sure your zoneminder user has at least search (x) permission on all the components of
If your ls(1) has the switch, you can use^W^W^W^W^W^W^W
Well, I *thought* ls had a switch to show all the directories in a pathname...
Anyways: try
$ ls -ld /usr/lib/zoneminder
$ ls -ld /usr/lib
$ ls -ld /usr
$ ls -ld /
and make sure that everything in the path has at least x permission for whatever user your webserver runs as (www, apache, whathaveyou); I don't think it needs r permission until the cgi-bin directory. You've already shown that's ok.
Posted: Mon Aug 12, 2019 6:31 pm
by Darkyere
I know it seems odd but it seems like it has execute everywhere
root@RPI2:/home/DYbvRBDO# ls -ld /usr/lib/zoneminder/cgi-bin
drwxr-xr-x 2 root www-data 4096 Jul 30 14:05 /usr/lib/zoneminder/cgi-bin
drwxr-xr-x 3 root root 4096 Jul 30 14:04 /usr/lib/zoneminder
drwxr-xr-x 101 root root 4096 Aug  9 11:52 /usr/lib/
drwxr-xr-x 11 root root 4096 Jul 25 15:54 /usr/
drwxr-xr-x 21 root root 4096 Jul 29 13:59 /
Posted: Mon Aug 12, 2019 6:36 pm
by Baylink
Yup, it appears you do... unless that's not the /cgi-bin/ that it's complaining about.
It's not possible you have more than one apache installed on that machine, is it?
Posted: Mon Aug 12, 2019 6:44 pm
by Darkyere
Hmm that is a possibility i suppose.
I have OpenHAB2, RPI-Monitor, and Shinobi (Dont mind the wrong name i think its gettting cencured its S-h-i-n-o-b-i) that are using some sort of web interface.
I think that OpenHAB2 runs on some sort of apache version or something similar but im not sure.
The weird part even with another version of Apache 2.
When it was Raspbian Stretch and Zoneminder 1.30.4 it did coexcist fine.
But now with Raspbian Buster and Zoneminder 1.32.3 im suddenly having these weird issue.
Posted: Mon Aug 12, 2019 7:30 pm
by Darkyere
Okay just for the heck of it i tried putting a script i found on the net in /usr/lib/cgi-bin
nano /usr/lib/cgi-bin/test.pl
#!/usr/bin/perl -w
print "Content-type: text/html\r\n\r\n";
print "Hello there!<br />\nJust testing .<br />\n";
for ($i=0; $i<10; $i++)
print $i."<br />";
When giong to http://IP/cgi-bin/test.pl
i get
Hello there!
Just testing .
0
1
2
3
4
5
6
7
8
9
Does this mean zoneminder or Apache2 is pointed in the wrong direction somewhere ?
Or is it just apache2 pointing there ?
Weird i can get acces to that one but not as http://IP/zm
Posted: Mon Aug 12, 2019 8:23 pm
by Darkyere
Okay this is starting to make sence.
Zoneminder is right now "looking" inside /usr/lib/cgi-bin
I allso found that the path for cgi-bin / zms for zoneminder is controlled by a fil here
 ls -lah /etc/zm/conf.d
total 24K
drwxr-xr-x 2 root root 4.0K Aug  9 09:19 .
drwxr-xr-x 3 root root 4.0K Aug 12 21:40 ..
-rw-r--r-- 1 root root 2.0K Aug  9 09:17 01-system-paths.conf
-rw-r--r-- 1 root root  395 Dec  8  2018 02-multiserver.conf
-rw-r--r-- 1 root root  126 Aug  7 20:13 backupandsync.conf
-rw-r--r-- 1 root root  740 Dec  8  2018 README
nano /etc/zm/conf.d/01-system-paths.conf
ZM_PATH_ZMS=/cgi-bin
if i change that to etc
ZM_PATH_ZMS=/usr/lib/zoneminder/cgi-bin
i finally get another respond in the window now saying
The requested URL /usr/lib/zoneminder/cgi-bin was not found on this server.
Posted: Fri Aug 16, 2019 1:40 pm
by Darkyere
I found the solution. And i hope its its working not.
I changed
nano /etc/apache2/conf-enabled/zoneminder.conf
from the long bloated version i found recommended on the net to the origional file
    AllowOverride All
    Require all granted
</Directory>
        AllowOverride None
           # Apache 2.4
           Require all granted
        </IfModule>
    </Directory>
  </IfModule>
</Directory>
    AllowOverride All
</Directory>
# And created
nano /etc/zm/conf.d/custom_paths.conf
ZM_PATH_ZMS=/zm/cgi-bin/nph-zms
ZM_PATH_CGI=/usr/lib/zoneminder/cgi-bin
Restarted apache2 since i changed the apache2 configuration file /etc/apache2/conf-enabled/zoneminder.conf
And restarted ZoneMinder since i created this new configuration file /etc/zm/conf.d/custom_paths.conf
And now i have a streaming window running with no problem
Posted: Fri Aug 16, 2019 8:23 pm
by Baylink
#nice
