Camera function pop-up window blank
skydreamer
Post by skydreamer »
I am unable to change camera function from Console view because the pop-up window with monitoring selections (Modect, Record,...) comes up blank in Firefox and throws http error 500 in Chrome. The link is https://server:8443/zm/index.php?view=f ... =1&popup=1. I am running the server on a non-standard https port. The system is CentOS 7.7, selinux in permissive mode. No specific errors in syslog or zm log. Any idea what might be wrong or where else to look?
Re: Camera function pop-up window blank
I believe I have already fixed it today. Update.
Alternatively you can click on anything else to get into full edit mode and change the function there.
skydreamer
Updated to zoneminder.x86_64 0:1.33.14-1.360.20191004gitg5aa639ff7.el7 still the same issue with the pop-up.
The full edit mode works fine.
Th error now comes up in the log:
500 Internal Server Error
/zm/?view=function&mid=1&popup=1
I pushed the fix on the 5th.
skydreamer
Cheers, the fix made it through in zoneminder-1.33.14-1.367.20191007gitg3db9375af.el7.x86_64
The pop-up window is working fine now.
