Page 1 of 1
32-bit OS officially supported?
Posted: Sun Oct 13, 2019 8:48 am
by papinkivi
Hey,
official documentation says that you can use Athlon XP processor to capture up to four cameras. The processor is 32-bit and the Debian Guide doesn't mention is it 64-bit or 32-bit. Ubuntus seems to be 64-bit nowadays.
I can install zoneminder on 32-bit debian, but can't get camera working. Should it work?
Can I use old server hardware to do the job. Specs are:
- 2 x 32-bit CPUs
- 11 Gb RAM (5,5 Gb for each CPU, my quess is that 6 Gb per CPU is maximum in 32-bit achitechture)
- 5 x 32 Gb SCSI HDD
Should I try harder on 32-bit handware or should I forget them?
Which distro you prefer Debian / Ubuntu / Other?
I found sources only one place: viewtopic.php?f=36&t=27783
Should the official documentation say something about 32-bit arch if it really doesn't work or not supported any more?!?
Re: 32-bit OS officially supported?
Posted: Wed Oct 16, 2019 12:13 am
by iconnor
It should work. I can do some testing.
You are likely better off with debian as ubuntu has discontinued 32bit support.
Posted: Sat Oct 19, 2019 3:53 pm
by iconnor
Works fine on my 32bit debian install.
