Page 1 of 1
Cheap Chinise camera PTZ control
Posted: Mon Oct 14, 2019 6:00 pm
by komatim
I have a chinise PTZ camera, I followed the official installation guide, I get the stream without a problem.
I have problems only with the PTZ settings.
With ONVIF Device Manager and iSpy connect programs, the ptz working without any problem, but in ZoneMinder not.
I tried a lot of settings, without any effect.
Can anyone help me?
Camera type:
https://www.ebay.com/itm/5MP-HD-IP-CCTV ... 100623.m-1
Camera user name:admin
Camera password: blank
Zoneminder Version: v1.32.3
Zoneminder Log:
2019-10-14 19:59:13.971287 zmc_m4[3217].INF-zm_monitor.cpp/2477 [Monitor-4: images:500 - Capturing at 12.50 fps, capturing bandwidth 18178bytes/sec]
2019-10-14 19:59:05.566705 zmc_m4[3217].INF-zm_monitor.cpp/2477 [Monitor-4: images:400 - Capturing at 12.50 fps, capturing bandwidth 18196bytes/sec]
2019-10-14 19:58:57.167397 zmc_m4[3217].INF-zm_monitor.cpp/2477 [Monitor-4: images:300 - Capturing at 11.11 fps, capturing bandwidth 11615bytes/sec]
2019-10-14 19:58:55.343200 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:54.317020 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:54.116740 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:53.098560 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:53.079760 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:52.054210 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:52.033600 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:50.540400 zmcontrol[1989].ERR-zmcontrol.pl [Error check failed:'401 Unauthorized']
2019-10-14 19:58:48.774926 zmc_m4[3217].INF-zm_monitor.cpp/2477 [Monitor-4: images:200 - Capturing at 5.88 fps, capturing bandwidth 7584bytes/sec]
2019-10-14 19:58:44.502150 zmfilter_2[1209].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-10-14 19:58:44.489160 zmfilter_1[1205].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-10-14 19:58:31.255353 zmc_m4[3217].INF-zm_monitor.cpp/2477 [Monitor-4: images:100 - Capturing at 16.67 fps, capturing bandwidth 24433bytes/sec]
2019-10-14 19:58:25.184645 zmc_m4[3217].INF-zm_monitor.cpp/2477 [Monitor-4: images:1 - Capturing at 33.33 fps, capturing bandwidth 13633bytes/sec]
2019-10-14 19:58:22.647110 zmcontrol[1989].ERR-zmcontrol.pl [Can't access member of object of class ZoneMinder::Control::onvif]
2019-10-14 19:58:22.638290 zmdc[1099].WAR-zmdc.pl [Can't find process with command of 'zma -m 4']
2019-10-14 19:58:22.622744 zmc_m4[3217].INF-zm_ffmpeg_camera.cpp/378 [Stream open rtsp://admin:@192.168.1.72:554, parsing streams...]
2019-10-14 19:58:22.576831 zmc_m4[3217].INF-zm_ffmpeg_camera.cpp/163 [Priming capture from rtsp://admin:@192.168.1.72:554]
2019-10-14 19:58:22.570964 zmc_m4[3217].INF-zmc.cpp/223 [Starting Capture version 1.32.3]
2019-10-14 19:58:22.529350 zmdc[1099].WAR-zmdc.pl [Can't find process with command of 'zmtrack.pl -m 4']
2019-10-14 19:58:22.395840 zmdc[1099].INF-zmdc.pl ['zmc -m 4' starting at 19/10/14 19:58:22, pid = 3217]
2019-10-14 19:58:22.395420 zmdc[3217].INF-zmdc.pl ['zmc -m 4' started at 19/10/14 19:58:22]
2019-10-14 19:58:22.326040 zmdc[1099].INF-zmdc.pl ['zmc -m 4' exited normally]
2019-10-14 19:58:22.264971 zmc_m4[3159].INF-zm_signal.cpp/40 [Got signal 15 (Terminated), exiting]
2019-10-14 19:58:22.258360 zmdc[1099].INF-zmdc.pl ['zmc -m 4' sending stop to pid 3159 at 19/10/14 19:58:22]
2019-10-14 19:58:22.148100 zmdc[1099].WAR-zmdc.pl [Can't find process with command of 'zma -m 4']
2019-10-14 19:58:22.035650 zmdc[1099].WAR-zmdc.pl [Can't find process with command of 'zmtrack.pl -m 4']
2019-10-14 19:58:19.256037 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3900 - Capturing at 11.11 fps, capturing bandwidth 16210bytes/sec]
2019-10-14 19:58:10.849901 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3800 - Capturing at 12.50 fps, capturing bandwidth 18231bytes/sec]
2019-10-14 19:58:02.445192 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3700 - Capturing at 11.11 fps, capturing bandwidth 11541bytes/sec]
2019-10-14 19:57:53.983819 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3600 - Capturing at 12.50 fps, capturing bandwidth 18142bytes/sec]
2019-10-14 19:57:45.576819 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3500 - Capturing at 12.50 fps, capturing bandwidth 18167bytes/sec]
2019-10-14 19:57:44.488710 zmfilter_2[1209].INF-zmfilter.pl [Checking filter Update DiskSpace update disk space returned 0 events ]
2019-10-14 19:57:44.475760 zmfilter_1[1205].INF-zmfilter.pl [Checking filter PurgeWhenFull delete returned 0 events ]
2019-10-14 19:57:37.166279 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3400 - Capturing at 11.11 fps, capturing bandwidth 16222bytes/sec]
2019-10-14 19:57:28.777284 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3300 - Capturing at 12.50 fps, capturing bandwidth 18204bytes/sec]
2019-10-14 19:57:20.295735 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3200 - Capturing at 11.11 fps, capturing bandwidth 11585bytes/sec]
2019-10-14 19:57:11.897884 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3100 - Capturing at 12.50 fps, capturing bandwidth 18126bytes/sec]
2019-10-14 19:57:03.498030 zmc_m4[3159].INF-zm_monitor.cpp/2477 [Monitor-4: images:3000 - Capturing at 12.50 fps, capturing bandwidth 18190bytes/sec]
Screenshots:
- Picture4.png (114.81 KiB) Viewed 15940 times
- Picture3.png (238.85 KiB) Viewed 15940 times
- Picture2.png (865.09 KiB) Viewed 15940 times
Re: Cheap Chinise camera PTZ control
Posted: Tue Oct 15, 2019 8:17 am
by komatim
Any idea?
I can give VNC access to the Ubuntu server if anyone can help.
Posted: Tue Oct 15, 2019 3:02 pm
by pms
Hi Komatin,
Do you use an empty password for user 'admin' 'or text 'blank'?
If i look at the error log I would suggest you try to set a real password for user admin and then try again.
Posted: Tue Oct 15, 2019 6:15 pm
by komatim
pms wrote: ↑Tue Oct 15, 2019 3:02 pm
Hi Komatin,
No password for admin user. (empty)
I tried with and without user name.
It works with another program.
For example: ONVIF Device Manager is OK
- 1.jpg (40.27 KiB) Viewed 15884 times
- 3.jpg (63.27 KiB) Viewed 15884 times
Thank you!
Posted: Tue Oct 15, 2019 11:38 pm
by iconnor
You need to update to latest master. I have made some improvements that should solve your problem.
If on ubuntu, do
sudo add-apt-repository ppa:iconnor/zoneminder-master
sudo apt-get update
sudo apt-get install zoneminder
Posted: Wed Oct 16, 2019 7:39 pm
by komatim
iconnor wrote: ↑Tue Oct 15, 2019 11:38 pm
If on ubuntu, do
sudo apt-get update
Can you please check the log after update:
2019-10-16 15:36:59.112897 zmc_m1[5390].INF-zm_monitor.cpp/2539 [Monitor-1: images:600 - Capturing at 7.69 fps, capturing bandwidth 10102bytes/sec]
2019-10-16 15:36:46.621469 zmc_m1[5390].INF-zm_monitor.cpp/2539 [Monitor-1: images:500 - Capturing at 8.33 fps, capturing bandwidth 10897bytes/sec]
2019-10-16 15:36:34.123668 zmc_m1[5390].INF-zm_monitor.cpp/2539 [Monitor-1: images:400 - Capturing at 7.69 fps, capturing bandwidth 10055bytes/sec]
2019-10-16 15:36:24.933410 zmcontrol_1[5518].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:24.776900 zmcontrol_1[5505].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:24.587070 zmcontrol_1[5502].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:24.383950 zmcontrol_1[5475].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:24.340710 zmcontrol_1[5468].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:24.232300 zmcontrol_1[5463].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:24.019780 zmcontrol_1[5456].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:23.994480 zmcontrol_1[6030].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
Can't locate DateTime.pm in @INC (you may need to install the DateTime module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/share/perl5/ZoneMinder/Control/Netcat.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Control/Netcat.pm line 33.
Compilation failed in require at /usr/share/perl/5.26/Module/Load.pm line 77.
Can't locate ZoneMinder/Control/Netcat in @INC (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/share/perl/5.26/Module/Load.pm line 77.]
2019-10-16 15:36:23.983950 zmcontrol_1[6030].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:23.935730 zmcontrol_1[5451].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:23.748150 zmcontrol_1[5445].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:23.679230 zmcontrol_1[6023].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:23.656620 zmcontrol_1[6023].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:23.466590 zmcontrol_1[5441].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:23.315280 zmcontrol_1[6016].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:23.294690 zmcontrol_1[6016].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:23.086400 zmcontrol_1[5435].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:22.943270 zmcontrol_1[6011].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:22.924630 zmcontrol_1[6011].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:22.891970 zmcontrol_1[5428].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:22.819500 zmcontrol_1[5422].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:22.551230 zmcontrol_1[6003].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:22.535750 zmcontrol_1[6003].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:22.171240 zmcontrol_1[6000].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:22.152140 zmcontrol_1[6000].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:22.108110 zmcontrol_1[5418].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:21.806540 zmcontrol_1[5993].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:21.792540 zmcontrol_1[5993].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:21.621508 zmc_m1[5390].INF-zm_monitor.cpp/2539 [Monitor-1: images:300 - Capturing at 8.33 fps, capturing bandwidth 10868bytes/sec]
2019-10-16 15:36:21.536050 zmcontrol_1[5413].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:21.327270 zmcontrol_1[5986].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:21.308610 zmcontrol_1[5986].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:20.951240 zmcontrol_1[5980].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:20.931250 zmcontrol_1[5980].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:20.651290 zmcontrol_1[5407].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:20.619270 zmcontrol_1[5975].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:20.586240 zmcontrol_1[5975].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:20.251240 zmcontrol_1[5968].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:20.248410 zmcontrol_1[5404].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:20.219240 zmcontrol_1[5968].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:19.911230 zmcontrol_1[5962].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:19.884610 zmcontrol_1[5962].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:19.411250 zmcontrol_1[5956].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:19.394210 zmcontrol_1[5956].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:19.018810 zmcontrol_1[5950].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:19.002550 zmcontrol_1[5950].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:18.855250 zmcontrol_1[5401].ERR-zmcontrol.pl [Unable to connect to zmcontrol server at /var/run/zm/zmcontrol-1.sock]
2019-10-16 15:36:18.493660 zmcontrol_1[5941].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:18.448760 zmcontrol_1[5941].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:18.120680 zmcontrol_1[5935].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:18.078840 zmcontrol_1[5935].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:17.663580 zmcontrol_1[5929].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:17.647570 zmcontrol_1[5929].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:17.291270 zmcontrol_1[5921].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:17.277330 zmcontrol_1[5921].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:16.911250 zmcontrol_1[5914].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
2019-10-16 15:36:16.892630 zmcontrol_1[5914].INF-zmcontrol.pl [Starting control server 1/Netcat]
2019-10-16 15:36:16.519250 zmcontrol_1[5908].FAT-zmcontrol.pl [Can't load ZoneMinder::Control::Netcat
Posted: Thu Oct 17, 2019 8:36 pm
by iconnor
sudo apt-get install libdatetime-perl
Posted: Sat Oct 19, 2019 10:11 am
by Tomm
Unrelated to your original issue,
Does this camera have HTTP configuration webpages, or do you need to use the mobile app to configure the camera ?
thx,
Tom
Posted: Sat Oct 19, 2019 4:57 pm
by komatim
the camera doesn't have a web page
It requires a mobile application: YCC365
Posted: Sat Jul 11, 2020 10:58 pm
by kysdaddy
Has anyone figured out a consistent answer to this? I have Onvif Chinese Cameras. I have installed to zoneminder using
rtsp://192.168.1.18:554/user=admin_password=6QNMIQGe_channel=1_stream=0.sdp?real_stream I found this using the Onvif device manager program and OnvifDM works to control the Pan tilt and zoom.
This camera works fine in ZM, although it does not have an http access as my other cameras do, if I go to the IP address it installs an app to view and control with.
The Phone app that it uses is the Icsee app, all of my other cameras use Camhi.
Thanks for any help provided.
Chas
I
Posted: Tue Nov 10, 2020 1:52 pm
by oangelo
I have Onvif Chinese Camera that uses ICsee app, it is working in Zoneminder with the following config:
Source Path: rtsp://192.168.1.121:554/user=admin_password=d2gNs1nj_channel=0_stream=0.sdp?real_stream
Control:
Control Type: Netcat ONVIF
Control Address: 192.168.1.121:8899/onvif/ptz_service
Auto Stop Timeout: 0.5
PS: The ONVIF detection was not working on the Zoneminder running at my server, I had to install the Zoneminder on another machine and probe ONVIF with the command "zmonvif-probe.pl probe" to find the "Source Path".
Posted: Wed Nov 11, 2020 9:51 am
by extercy
I am using Besder and Hamrol? cheap China PTZ cameras which uses ICSee app. Got it working with rstp and PTZ.
rtsp://192.168.0.3:554/user=admin&password=1234&channel=1&stream=0.sdp?real_stream
this rtsp can be used for both since both the http login via Win 7 IE and some add-ons are the same. Both are basically the same expect one has Auto Tracking and Memory Location while the other does not.
ONVIF detection never work for both the cameras.
