Can't view images in timeline mode
tigerA
Post by tigerA »
Cameras in timeline mode are displayed randomly. For example, select one hour some times.
When you hover over the ruler, a preview is not always displayed
In logs seen that:
web_js 1333 ERR TypeError: event is undefined zm/cache/skins_classic_views_js_timeline-base-1571025627.js 29
Re: Can't view images in timeline mode
How up to date is your zm install? I've been testing/fixing timeline mode recently.
tigerA
Post by tigerA »
zm was updated to version 1.33.14-1-385... from zmrepo. Whats may happened?
Hmm, so the js error you listed is now fixed... might take a little while for packages to build. The rpm's build at night.
tigerA
Post by tigerA »
Ok. After update, will check this.
tigerA
Post by tigerA »
After update to new version (400), have another trouble (no record):
2019-10-18 14:40:46 zmc_m1 17021 ERR Unable to send packet Invalid data found when processing input, continuing zm_ffmpeg.cpp 548
2019-10-18 14:40:46 zmc_m1 17021 WAR Unable to receive frame 0: Success. error count is 0 zm_ffmpeg_camera.cpp 957
Return has to previouse version (385)
