Kubuntu 19.10 support - mysql 8 compatibility
ris2t
Post by ris2t »
Hi
Does Zoneminder have a ppa or ubuntu stream build for 19.10 (eoan) yet? Appreciated its early days. I see ppa:iconnor has 19.04(disco) as the highest.
Looking at the 1.32.3-2build1 ubuntu eoan package its seems to incompatible. After the upgrade from 19.04 various MySQL 8 version (reservered works and function changes) compatibility issues presented. I attempted a fresh zoneminder install but the database scripts aren't compatible. I see master has some patches.
Just wondering on a compatibility path or release timeframe, rather not build from source if I can avoid it.
Raymond
Re: Kubuntu 19.10 support - mysql 8 compatibility
The ppa will contain packages in a few minutes.I am aware of several issues with mysql. I just upgraded to Eoan yesterday so testing is ongoing.
clueless
Post by clueless »
Stupidly I also upgraded to 19.10 last night, and it would appear I also am having the same SQL related issues.
I saw your post, and tried to add your repository back into my system, however I get the following when I try:
E: The repository 'http://ppa.launchpad.net/iconnor/zoneminder-1.32/ubuntu eoan Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Am I too early? Or am I missing something completely?
ris2t
Post by ris2t »
iconnor wrote: Sun Oct 20, 2019 3:40 pm The ppa will contain packages in a few minutes.I am aware of several issues with mysql. I just upgraded to Eoan yesterday so testing is ongoing.
Thank you. Appreciate the efforts. Will await the release.
bkjaya1952
Post by bkjaya1952 »
I have installed Zoneminder successfully on Ubuntu 19.10, using mariadb-server-10.3 and zoneminder_1.33.14~20191101150513-disco_amd64.deb
For the installation details please refer the following link
https://bkjaya.wordpress.com/2019/11/03 ... th-mriadb/
The installation of Zoneminder with mysql 8 on Ubuntu 19.10 is described in the following links
https://bkjaya.wordpress.com/2020/01/04 ... ntu-19-10/
https://bkjaya.wordpress.com/2020/01/14 ... an-ermine/
