Not able to re-install Zoneminder
Posted: Fri Nov 08, 2019 5:42 pm
Suddenly all the event images disappeared and images for new events were not anymore saved to disk. Happened earlier also and re-installing Zoneminder has corrected the problem but I haven't been able to recover missed images. Today again all the images disappeared and I thought to re-install Zoneminder again, but now it seems that I'm not able to install it anymore with the script that I've used earlier. Any ideas?
Script Output below:
This script installs Zoneminder 1.32.x on Ubuntu 18.04 AMD64 with LAMP (MySQL) installed...
Press Enter to continue or Ctrl + c to quit
You must be logged in as root using sudo su ...
Next we will add the PPA repository, install and configure the system to run Zoneminder.
Press enter to continue
Reading package lists... Done
Building dependency tree
Reading state information... Done
software-properties-common is already the newest version (0.96.24.32.11).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Stable releases of ZoneMinder 1.32
This is to provide newer official packages for older ubuntu dists.
If you would like to make a donation to directly support this ppa, you may do so by sending paypal to paypal @ connortechnology.com, become a patron at https://www.patreon.com/zoneminder or send digital coins to the following addresses:
BTC: 143XJVxDQ1c1HF4vixuCZAqG6LDhSBQFwU
BCH: qpk8a4938am7ex37k2yfykyglkxg6v46v5jy8qw05c
ETH: 0xA23b82d94A3589A866529DE9db05E3ba8a37fed8
ECH: 0x93FC917d1B9d3EA6c83fC5E2b48C7314B00D9407
LTC: M9QT3SUywaEcPwMwvu9rFLVmMuugQzdPWK
More info: https://launchpad.net/~iconnor/+archive/ubuntu/zoneminder-1.32
Press [ENTER] to continue or Ctrl-c to cancel adding it.
Hit:1 http://ppa.launchpad.net/alex-p/tesseract-ocr/ubuntu bionic InRelease
Hit:2 http://ppa.launchpad.net/certbot/certbot/ubuntu bionic InRelease
Hit:3 http://ppa.launchpad.net/gezakovacs/ppa/ubuntu bionic InRelease
Hit:4 http://ppa.launchpad.net/iconnor/texon/ubuntu bionic InRelease
Hit:5 http://ppa.launchpad.net/iconnor/zoneminder-1.32/ubuntu bionic InRelease
Ign:6 http://ppa.launchpad.net/iconnor/zoneminder/ubuntu bionic InRelease
Hit:7 http://ppa.launchpad.net/iconnor/zoneminder-master/ubuntu bionic InRelease
Hit:8 http://ppa.launchpad.net/ondrej/php/ubuntu bionic InRelease
Hit:9 http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu bionic InRelease
Hit:10 http://ppa.launchpad.net/xapienz/curl34/ubuntu bionic InRelease
Err:11 http://ppa.launchpad.net/iconnor/zoneminder/ubuntu bionic Release
404 Not Found [IP: 91.189.95.83 80]
Get:12 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Hit:13 http://fi.archive.ubuntu.com/ubuntu bionic InRelease
Hit:14 http://fi.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:15 http://fi.archive.ubuntu.com/ubuntu bionic-backports InRelease
E: The repository 'http://ppa.launchpad.net/iconnor/zoneminder/ubuntu bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Target Packages (universe/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target Packages (universe/binary-i386/Packages) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target Packages (universe/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target Translations (universe/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target Translations (universe/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target Translations (universe/i18n/Translation-fi) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target DEP-11 (universe/dep11/Components-amd64.yml) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target DEP-11 (universe/dep11/Components-all.yml) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target DEP-11-icons-small (universe/dep11/icons-48x48.tar) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target DEP-11-icons (universe/dep11/icons-64x64.tar) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target CNF (universe/cnf/Commands-amd64) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
W: Target CNF (universe/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:6 and /etc/apt/sources.list:19
Get:1 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
Hit:2 http://fi.archive.ubuntu.com/ubuntu bionic InRelease
Hit:3 http://fi.archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:4 http://fi.archive.ubuntu.com/ubuntu bionic-backports InRelease
Hit:5 http://ppa.launchpad.net/alex-p/tesseract-ocr/ubuntu bionic InRelease
Hit:6 http://ppa.launchpad.net/certbot/certbot/ubuntu bionic InRelease
Hit:7 http://ppa.launchpad.net/gezakovacs/ppa/ubuntu bionic InRelease
Hit:8 http://ppa.launchpad.net/iconnor/texon/ubuntu bionic InRelease
Hit:9 http://ppa.launchpad.net/iconnor/zoneminder-1.32/ubuntu bionic InRelease
Ign:10 http://ppa.launchpad.net/iconnor/zoneminder/ubuntu bionic InRelease
Hit:11 http://ppa.launchpad.net/iconnor/zoneminder-master/ubuntu bionic InRelease
Hit:12 http://ppa.launchpad.net/ondrej/php/ubuntu bionic InRelease
Hit:13 http://ppa.launchpad.net/otto-kesselgulasch/gimp/ubuntu bionic InRelease
Hit:14 http://ppa.launchpad.net/xapienz/curl34/ubuntu bionic InRelease
Err:15 http://ppa.launchpad.net/iconnor/zoneminder/ubuntu bionic Release
./zm-install2: 11: ./zm-install2: cannot create /etc/php/7.2/apache2/php.ini: Directory nonexistent
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
zoneminder : Depends: libdate-manip-perl but it is not installable
Depends: libmime-lite-perl but it is not installable
Depends: libmime-tools-perl but it is not installable
Depends: libdbd-mysql-perl but it is not going to be installed
Depends: libdatetime-perl but it is not going to be installed
Depends: libsoap-wsdl-perl but it is not going to be installed
Depends: libcrypt-eksblowfish-perl but it is not going to be installed
Depends: libdata-entropy-perl but it is not going to be installed
Recommends: zoneminder-doc (>= 1.33.14~20191104212038-bionic) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Failed to enable unit: Unit file zoneminder.service does not exist.
Failed to start zoneminder.service: Unit zoneminder.service not found.
The user `www-data' is already a member of `video'.
ERROR: Conf zoneminder does not exist!
Module rewrite already enabled
Install complete.Press enter to continue
