Page 1 of 1
DS-2DE3304W-DE PTZ
Posted: Sun Nov 24, 2019 2:13 am
by joeCarmon
Has anybody gotten the Hikvision DS-2DE3304W-DE to work for PTZ? I have been struggling with this for quite some time. The camera streams, but I am unable to control it.
Re: DS-2DE3304W-DE PTZ
Posted: Sun Nov 24, 2019 3:43 am
by joeCarmon
Minor Update. I have set it for ONVIF, and think I am on the right track, but am getting http::80 (Bad hostname) in the error log for zmcontrol.
Posted: Tue Dec 03, 2019 7:18 pm
by joeCarmon
Bumping to see if anybody has any ideas.
Posted: Wed Dec 11, 2019 1:21 pm
by security_dude
I have it working on my machine. Make sure you are using this syntax under the control tab for the control address.
userid:password@server IP:port number
For example admin:passwrod@192.168.1.200:80
Did you create a script for it yet? The control device under the same tab should be your script name. Hope this helps.
Posted: Thu Dec 12, 2019 4:54 pm
by rockedge
does the Hikvision.pm work for these DS-2DE3304W-DE cameras?
Are the control commands correct in the control script?
Posted: Sun Dec 15, 2019 10:40 pm
by security_dude
PM sent with modified script for you to try out.
Posted: Mon Dec 16, 2019 1:53 pm
by rockedge
Thanks! I am reviewing some of the different control scripts so this info helps!
Posted: Sun Dec 29, 2019 11:28 pm
by kobold81
I have the DS-2DE2A404IW-DE3 working with the HikVision script provided by zoneminder.
Control Device: DS-2DE2A404IW-DE3
Control Address: admin:Password@10.10.4.21
Control Type: HikVision
Then click "Edit" next to Control Type.
Move: I clicked everything on
I entered Values at Pan, Tilt, zoom and clicked zoom on on.
I am still trying to figure out if a change in e.g. Pan steps dies anything ;-)
Posted: Tue Jul 21, 2020 4:47 pm
by kingsize
security_dude wrote: Wed Dec 11, 2019 1:21 pm I have it working on my machine. Make sure you are using this syntax under the control tab for the control address.
Thank you for posting. Can finally control my two from zm.
Posted: Tue Dec 08, 2020 8:20 pm
by jcarmon
I am working on getting the same camera up and running, would you care to post your script?
Posted: Fri Jan 15, 2021 4:43 pm
by Paranoid
Can you goto the following url on your camera and post the output?
http://<your camera>/ISAPI/PTZCtrl/channels/1/capabilities
Posted: Fri May 21, 2021 12:41 pm
by walt
I have the Hikvision DS-2DE2A404IW-DE3 and this is what I get:
<PTZChanelCap xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<AbsolutePanTiltPositionSpace>
<XRange>
<Min>0</Min>
<Max>3550</Max>
</XRange>
<YRange>
<Min>0</Min>
<Max>900</Max>
</YRange>
</AbsolutePanTiltPositionSpace>
<AbsoluteZoomPositionSpace>
<ZRange>
<Min>10</Min>
<Max>40</Max>
</ZRange>
</AbsoluteZoomPositionSpace>
<ContinuousPanTiltSpace>
<XRange>
<Min>-100</Min>
<Max>100</Max>
</XRange>
<YRange>
<Min>-100</Min>
<Max>100</Max>
</YRange>
</ContinuousPanTiltSpace>
<ContinuousZoomSpace>
<ZRange>
<Min>-100</Min>
<Max>100</Max>
</ZRange>
</ContinuousZoomSpace>
<maxPresetNum>300</maxPresetNum>
<maxPatrolNum>0</maxPatrolNum>
<maxPatternNum>0</maxPatternNum>
<maxLimitesNum>0</maxLimitesNum>
<maxTimeTaskNum>10</maxTimeTaskNum>
<controlProtocol opt="HIKVISION,PELCO-P,PELCO-D">PELCO-D</controlProtocol>
<controlAddress>0</controlAddress>
<PTZRs485Para xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<baudRate opt="2400,4800,9600,19200,38400">9600</baudRate>
<dataBits opt="5,6,7,8">8</dataBits>
<parityType opt="none,even,odd">none</parityType>
<stopBits opt="1,2">1</stopBits>
<flowCtrl opt="none,software,hardware">none</flowCtrl>
</PTZRs485Para>
<PresetNameCap xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<presetNameSupport>true</presetNameSupport>
<maxPresetNameLen max="20"/>
<specialNo opt="34,39,40,46,92,93,94"/>
</PresetNameCap>
<wiperStatusSupport>false</wiperStatusSupport>
<isSupportPosition3D>true</isSupportPosition3D>
<manualControlSpeed opt="compatible,pedestrian,nonMotorVehicle,motorVehicle,selfadaptive"/>
<isSpportPtzlimiteds>true</isSpportPtzlimiteds>
<oneKeyParkAction>true</oneKeyParkAction>
<oneKeyMenu>false</oneKeyMenu>
<ParkAction xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<enabled opt="true,false">false</enabled>
<Parktime min="5" max="720">5</Parktime>
<Action>
<ActionType opt="preset">preset</ActionType>
<ActionNum min="0" max="8">0</ActionNum>
</Action>
</ParkAction>
<TimeTaskList xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<TimeTaskBlock xmlns="http://www.hikvision.com/ver20/XMLSchema" version="2.0">
<dayOfWeek min="1" max="7">1</dayOfWeek>
<TimeTaskRange>
<TaskID min="0" max="10">0</TaskID>
<Task>
<TaskType opt="disable,preset,periodreboot,periodadjust">disable</TaskType>
<presetTaskNum min="0" max="8">0</presetTaskNum>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">1</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">2</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">3</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">4</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">5</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">6</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">7</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">8</TaskID>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<TaskID min="0" max="10">9</TaskID>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">2</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">3</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">4</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">5</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">6</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
<dayOfWeek min="1" max="7">7</dayOfWeek>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
<TimeTaskRange>
<Task>
</Task>
</TimeTaskRange>
</TimeTaskBlock>
</TimeTaskList>
<PTZMotionTrack opt="true,false"/>
</PTZChanelCap>
