Using centos 7, rpmfusion RPM ver 1.32.3
When I click on the server page it's blank, looking at http log I see,
PHP Fatal error: Can't use method return value in write context in /usr/share/zoneminder/www/skins/classic/views/server.php on line 42
additionally there is a HTTP/1.1" 500 error.
Is there any fix for this?
500 Error on "ADD NEW SERVER" page
Re: 500 Error on "ADD NEW SERVER" page
Came across your post and wondered if you'd managed to resolve the issue? I get the same and worked around this by manually adding the servers to the DB, which isn't ideal.
Regards,
Garry
Regards,
Garry
