Eoan PPA builds?
nixcamic
Eoan PPA builds?
Post by nixcamic »
Any ideas when the Eoan PPA builds will be working? I'm currently running builds from source but it would be nice to be able to upgrade with a simple apt.
Re: Eoan PPA builds?
Eoan builds are present
ppa is ppa:iconnor/zoneminder-master
latest is 1.33.15~20191204090030-eoan
Eoan build status shows failed (red x) in the master PPA
Right. Use zmrepo instead.
https://zmrepo.zoneminder.com
To add the zmrepro:
sudo nano /etc/apt/sources.list
Add the following line to the end of the file
deb https://zmrepo.zoneminder.com/debian/master eoan/
CTRL+o then [Enter] to save
CTRL+x to exit
Install the following and retrieve the key from the repro
sudo apt install apt-transport-https gnupg
wget -O - https://zmrepo.zoneminder.com/debian/ar ... eyring.gpg | sudo apt-key add -
Edit: the forum truncates the above entry. Should include: debian/archive-keyring.gpg
Important - Make sure the above "wget" process completes without error! If it does not complete you will not get the most recent Zoneminder version this procedure is written for.
sudo apt update
