Help with configuration of ULAR Q5
Posted: Sat Dec 07, 2019 9:40 pm
Hi all... I already search here on forum and in google about how configure this ipcam in zoneminder and make some tests but still not working.
I discover a valid RTCP url for work in VLC:
- rtsp://admin:<PASS>@<IP>:554/route
But if I try to configure this on ZM as remote / RTP/RTCP and the video never appear and in browser console appear this error message:
"getStreamCmdResponse stream error: Socket /var/run/zm/zms-225817s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information"
