I'm getting the following error messages in my apache 2 error log.
Can anyone please assist me? all monitors are working and displaying video in the montage.
This server is running 1.33.15
I made sure CGI is enabled. I have no idea how to check if the PATH_ZMS is set correctly, but I don't think I would be getting video if it wasn't. I also went and installed cambozilla but have never needed it on any of the other zone minder servers I've built.
This is on x86 hardware, htop shows about 30% cpu usage, and about 25% ram usage, so the server is not over loaded.
[Wed Dec 18 17:46:53.161650 2019] [:error] [pid 15724] [client 192.168.1.100:61170] ERR [Socket /var/run/zm/zms-042480s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.], referer: https://zm.mydomain.com/zm/?view=montage
[Wed Dec 18 17:46:53.355721 2019] [cgi:error] [pid 15385] [client 192.168.1.100:61178] AH01215: Unable to connect to zmc process. Please ensure that it is running.: /usr/lib/zoneminder/cgi-bin/nph-zms, referer: https://zm.mydomain.com/zm/?view=montage
Socket /var/run/zm/zms-813930s.sock
Re: Socket /var/run/zm/zms-813930s.sock
Have you checked paths?
/etc/zm/conf.d/01-system-paths.conf
Production: zm 1.34.26 - Debian 11 | Test: zm 1.36.33 - Debian 12
