Help needed for installation
behrendorff
Post by behrendorff »
I am working on installing zoneminder on Debian, but are having some issues.
I am following this guide: https://wiki.zoneminder.com/Debian_10_B ... pro_Master
Everything works fine, untill I try to run the sudo apt install zoneminder, which gives me the error: E: Unable to locate package zoneminder.
This is what my sources.list looks like:
Can anybody see, what I am doing wrong?
Re: Help needed for installation
Ran that install yesterday on a Pi 3b+ with Buster. Had no issues. Make sure the wget command completes. Also best to become root with sudo su and leave out the sudo on the commands.
If I find time tomorrow I will load up Buster on my test PC and proof the install steps.
behrendorff
Thank you
Made a couple of changes in the install procedure to reflect updates to Zoneminder. Removed some confusing and unneeded steps. Provided a link to good instructions for LAMP on Debian Buster.
This procedure will likely still work with the release of Zoneminder 1.34.x (next week?) with a slight adjustment in sources.list.
Happy Holidays!
I think you have an extra /
the zmrepo line should be
deb https://zmrepo.zoneminder.com/debian/master buster/
note the lack of / after master.
iconnor wrote: Wed Dec 25, 2019 4:34 pm I think you have an extra /
It is correct in the WIKI.
