Clean installation on Ubuntu 18.04 - Cameras not working
Posted: Sun Dec 29, 2019 2:42 pm
Hello, guys,
I've just installed 18.04 and Zoneminder 1.32 using the first script on this page:
As far as I can tell, everything went smoothly. Then I used the camera configurations from my old ZM install, but all three cameras (two models in total) are not working. The logs show the following after I try to view one of the cameras:
I'm using Firefox, so cambozola shouldn't be needed, nph-zms is set at the same path as my old zoneminder install... The only thing I can think of is that I've not setup CGI in apache, since this is a new install, which I'm not sure how to do - any links or help is much appreciated!
019-12-29 16:33:43 zmwatch 17506 ERR Memory map file '/dev/shm/zm.mmap.1' should have been 1160 but was instead 0 zmwatch.pl
2019-12-29 16:33:38 web_php 2178 ERR Socket /var/run/zm/zms-923328s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2048
2019-12-29 16:33:38 zms_m1 17572 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:38 zms_m1 17572 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:38 zms_m1 17572 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:37 zms_m1 17568 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:37 zms_m1 17568 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:37 zms_m1 17568 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:35 zms_m1 17567 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:35 zms_m1 17567 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:35 zms_m1 17567 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:35 web_php 12696 ERR Socket /var/run/zm/zms-809038s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2048
2019-12-29 16:33:34 zms_m1 17563 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:34 zms_m1 17563 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:34 zms_m1 17563 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:33 web_php 15524 ERR Socket /var/run/zm/zms-278258s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2048
2019-12-29 16:33:33 zmwatch 17506 ERR Memory map file '/dev/shm/zm.mmap.1' should have been 1160 but was instead 0 zmwatch.pl
2019-12-29 16:33:33 zmwatch 17506 INF Restarting capture daemon for Cafe-In, shared data not valid zmwatch.pl
2019-12-29 16:33:33 zmdc 17455 INF Command 'zmc -m 1' removed from pending list at 19/12/29 16:33:33 zmdc.pl
2019-12-29 16:33:33 zms_m1 17562 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:33 zms_m1 17562 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:33 zms_m1 17562 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:32 zms_m1 17556 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:32 zms_m1 17556 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:32 zms_m1 17556 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:31 zms_m1 17554 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:31 zms_m1 17554 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:31 zms_m1 17554 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:31 web_php 12696 ERR Socket /var/run/zm/zms-628397s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2048
2019-12-29 16:33:30 zms_m1 17550 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:30 zms_m1 17550 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:30 zms_m1 17550 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:29 web_php 12696 ERR Socket /var/run/zm/zms-450232s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2048
2019-12-29 16:33:29 zms_m1 17549 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:29 zms_m1 17549 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:29 zms_m1 17549 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:27 zms_m1 17545 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:27 zms_m1 17545 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:27 zms_m1 17545 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:27 zms_m1 17544 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:27 zms_m1 17544 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:27 zms_m1 17544 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:27 web_php 1501 ERR Socket /var/run/zm/zms-752322s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php 2048
2019-12-29 16:33:26 zms_m1 17540 ERR Got empty memory map file size 0, is the zmc process for this monitor running? zm_monitor.cpp 538
2019-12-29 16:33:26 zms_m1 17540 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 48
2019-12-29 16:33:26 zms_m1 17540 ERR Unable to connect to zmc process for monitor 1 zms.cpp 254
2019-12-29 16:33:24 zmdc 17455 INF 'zmc -m 1' exited normally zmdc.pl
2019-12-29 16:33:23 zmc_m1 17531 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2019-12-29 16:33:23 zmdc 17455 INF 'zmc -m 1' sending stop to pid 17531 at 19/12/29 16:33:23 zmdc.pl
2019-12-29 16:33:23 zmwatch 17506 INF Restarting capture daemon for Cafe-In, no image since startup. Startup time was 1577629989 - now 1577630003 > 5
