Warning: I used a very slow class 4 SD card since it is going to be used for only a boot partition
in the end. All operations with it take enormous amount of time. But I don't care as it will
not be used for actual work this RPI is intended for.
First 4 steps I did on my MAC. But any Linux computer could be used as well. Just replace diskutil
command with whatever Linux uses to unmount an fs.
1.
diskutil unmount /Volumes/<whatever_name_your_SD_card_has>
Volume boot on disk4s1 unmounted
computer. Check before overwriting it. "df" or "disk utility" could help with it.
On Linux use "df", "lsblk" or "blkid". I warned you!
2.
dd if=/tmp/raspbian.img of=/dev/disk4 bs=1m conv=sync
2144+0 records in
2144+0 records out
2248146944 bytes transferred in 917.897363 secs (2449236 bytes/sec)
3.
touch /Volumes/boot/ssh
diskutil unmount /Volumes/boot
Next steps are performed on Raspberry PI. I used the latest RPI 4 B.
5. Boot RPI using this SD card. Use Ethernet cable, at least for now.
6. Find this RPI's IP and login (ssh) with pi/raspberry. You can find IP in your DHCP server's "current leases" list.
7. Don't forget to change password
8. Attach USB HDD. I use 4 TB external USB-3 HDD. Btw, it came with a regular USB-3 cable. So, I had to
get another one with additional USB power connector off Ebay. I connect it to a 60W power supply, which
also powers RPI. It has 6 USB sockets rtated 2.4 A each. So, I can probably connect another USB HDD
to it.
9. Look for USB HDD. In my case it is /dev/sda
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 3.7T 0 disk
└─sda1 8:1 0 3.7T 0 part
mmcblk0 179:0 0 3.7G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 3.4G 0 part /
one if you already have a partition that satisfies you. Like in the above case, I have an Linux
type partition that occupies the whole drive. But for the sake of this tutorial I will delete
and recreate it.
dd if=/dev/zero of=/dev/sda bs=1M count=1000
lsblk
fdisk /dev/sda
Welcome to fdisk (util-linux 2.33.1).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Device does not contain a recognized partition table.
The size of this disk is 3.7 TiB (4000787029504 bytes). DOS partition table format cannot be used on drives for volumes larger than 4294966784 bytes for 512-byte sectors. Use GUID partition table format (GPT).
Created a new DOS disklabel with disk identifier 0x47d1a7f2.
Command (m for help): g
Created a new GPT disklabel (GUID: C9252DF5-BBE3-8D41-A6A1-146CB4C56AC0).
Command (m for help): n
Partition number (1-128, default 1):
First sector (2048-7814037133, default 2048):
Last sector, +/-sectors or +/-size{K,M,G,T,P} (2048-7814037133, default 7814037133):
Created a new partition 1 of type 'Linux filesystem' and of size 3.7 TiB.
Command (m for help): w
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
lsblk
dd if=/dev/mmcblk0p2 of=/dev/sda1 bs=1M
3521+1 records in
3521+1 records out
3692560384 bytes (3.7 GB, 3.4 GiB) copied, 80.5194 s, 45.9 MB/s
e2fsck -f /dev/sda1
e2fsck 1.44.5 (15-Dec-2018)
rootfs: recovering journal
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Free blocks count wrong (602687, counted=560037).
Fix<y>? yes
Free inodes count wrong (180977, counted=180594).
Fix<y>? yes
rootfs: ***** FILE SYSTEM WAS MODIFIED *****
rootfs: 44750/225344 files (0.3% non-contiguous), 341467/901504 blocks
resize2fs /dev/sda1
resize2fs 1.44.5 (15-Dec-2018)
Resizing the filesystem on /dev/sda1 to 976754385 (4k) blocks.
The filesystem on /dev/sda1 is now 976754385 (4k) blocks long.
mount /dev/sda1 /mnt
16. Get the PARTUUIDs for partitions.
blkid
/dev/mmcblk0p1: LABEL_FATBOOT="boot" LABEL="boot" UUID="5203-DB74" TYPE="vfat" PARTUUID="6c586e13-01"
/dev/mmcblk0p2: LABEL="rootfs" UUID="2ab3f8e1-7dc6-43f5-b0db-dd5759d51d4e" TYPE="ext4" PARTUUID="6c586e13-02"
/dev/sda1: LABEL="rootfs" UUID="2ab3f8e1-7dc6-43f5-b0db-dd5759d51d4e" TYPE="ext4" PARTUUID="6debc4c1-0e9f-864e-ba94-ec95db099690"
/dev/mmcblk0: PTUUID="6c586e13" PTTYPE="dos"
PARTUUID for the new root partition is 6debc4c1-0e9f-864e-ba94-ec95db099690
17. Edit /boot/cmdline.txt: replace PARTUUID, add a delay for USB HDD to become ready.
nano /boot/cmdline.txt
New content:
console=serial0,115200 console=tty1 root=PARTUUID=6debc4c1-0e9f-864e-ba94-ec95db099690 rootdelay=5 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
18. Edit /etc/fstab on the USB drive (/mnt/etc/fstab actually).
To make boot filesystem readonly add ",ro". Warning, after this you won't be able to install some updates
Replace PARTUUID for the root system too.
PARTUUID=6c586e13-01 /boot vfat defaults,ro 0 2
PARTUUID=6debc4c1-0e9f-864e-ba94-ec95db099690 / ext4 defaults,noatime 0 1
19. Reboot
After the reboot:
df
Filesystem 1K-blocks Used Available Use% Mounted on
[b]/dev/root 3846750000 1272876 3669881928 1% /[/b]
devtmpfs 860916 0 860916 0% /dev
tmpfs 993012 0 993012 0% /dev/shm
tmpfs 993012 16804 976208 2% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 993012 0 993012 0% /sys/fs/cgroup
/dev/mmcblk0p1 258095 53933 204162 21% /boot
tmpfs 198600 0 198600 0% /run/user/1000
20.1.
fdisk /dev/mmcblk0
Command (m for help): d
Partition number (1,2, default 2): 2
Partition 2 has been deleted.
Command (m for help): p
Disk /dev/mmcblk0: 3.7 GiB, 3965190144 bytes, 7744512 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x6c586e13
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 532479 524288 256M c W95 FAT32 (LBA)
Syncing disks.
dd if=/dev/mmcblk0 of=/var/backups/boot_backup bs=1M count=260
260+0 records in
260+0 records out
272629760 bytes (273 MB, 260 MiB) copied, 5.96281 s, 45.7 MB/s
