Need help with audio issue with ffmpeg
RockUser
Post by RockUser »
Hello all. I am running zoneminder version 1.32.3. I have a camera that can record audio and when I view it through something like VLC the audio comes though just fine, but when I review the recordings the audio is not there. I know zoneminder doesn't support audio in its live view but it's not in the recordings either. I am using ffmpeg with h264 passthrough and I have the include audio box ticked in the options menu.
I was wondering if anyone had any advice where to try and fix this problem.
Thank you.
Re: Need help with audio issue with ffmpeg
Please update to latest master.
I fixed a lot of problems related to recording audio.
RockUser
Post by RockUser »
Thank you for the reply. I'm still a noob with zoneminder though, Did you mean for me to upgrade to version 1.33?
Yes, although now we have 1.34.0
