Changing anything in "Control capabilities" causes SOL-ERR
simonpg
Post by simonpg »
I hesitate to post this because I feel that I must be doing something funDUHmentally wrong. I am working on the Amcrest HTTP API and associated Amcrest_HTTP.pm script, because I have Amcrest cameras and it seems that they can do more than the current script supports. However, any change to Control Capabilities causes
"SQL-ERR 'SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect integer value: '' for column `zm`.`Controls`.`CanMoveDiag` at row 1', statement was 'UPDATE Controls SET `Id`=?
and a dump of all the parameter names
WHERE Id=?' params:40,1,0,1,0,0,1,1,1,0,,,0,0,0,0,,0,0,,0,1,0,0,0,0,,0,0,,0,1,,,1,0,0,0,0,,0,0,,,,,,0,0,0,0,,0,0,,,,,,0,0,0,0,,0,0,,,,,,0,0,0,0,,0,0,,,,,,0,0,0,0,,0,0,1,5,,,Amcrest HTTP API,Ffmpeg,Amcrest_HTTP,40
I'm guessing those undefined values are what are causing the "Incorrect integer value" error, but I am no DBA. I tried changing Control Capabilities on other cameras and come up with the same error.
I should add that I am on version 1.33.16 on Debian Buster.
Re: Changing anything in "Control capabilities" causes SOL-ERR
Unfortunately when running master, telling us 1.33.16 isn't very helpful. We've been at 1.33.16 since before christmas.
We need to know exactly when you package is from, which you can get with dpkg -s zoneminder
I might suggest that you just need to update. I did some work in there over the holidays and likely fixed this problem.
simonpg
Post by simonpg »
# dpkg -s zoneminder
Package: zoneminder
Status: install ok installed
Priority: optional
Section: net
Installed-Size: 40401
Maintainer: Isaac Connor <isaac@zoneminder.com>
Architecture: amd64
Version: 1.33.16~20191225.23-buster
# apt update
Ign:1 https://zmrepo.zoneminder.com/debian/master buster/ InRelease
Hit:2 https://zmrepo.zoneminder.com/debian/master buster/ Release
Hit:4 http://mirrors.syringanetworks.net/debian buster InRelease
Get:5 http://mirrors.syringanetworks.net/debian buster-updates InRelease [49.3 kB]
Hit:6 http://security.debian.org/debian-security buster/updates InRelease
Fetched 49.3 kB in 5s (9,383 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
Just to be clear, I updated to this point before I posted this error; and the error does still exist.
Dang it, zmrepo hasn't been updating. I'll fix that. Please update.
Please also note that I just released 1.34.0 so if you don't get up to that version, you are not up to date.
simonpg
Post by simonpg »
No updates from zmrepo :(
simonpg
Post by simonpg »
I upgraded to Version: 1.34.0-buster. This issue has been fixed. :)
hurray!
