Lots of errors. Camera feed being shutdown/restarted.
johnnyfive
Post by johnnyfive »
Alright so I just deleted all my zoneminder files and restarted everything... I'm not sure all my previous configs.
I'm getting this error though for one of my cameras
Date/Time
ComponentServerPIDLevelMessageFileLine
2020-01-22 16:30:14zma_m24620ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:30:14zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:29:13zmwatch976ERRMemory map file '/dev/shm/zm.mmap.2' should have been 1160 but was instead 0zmwatch.pl
2020-01-22 16:29:10zma_m24578ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:29:10zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:29:05zma_m24557ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:29:05zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:29:04zma_m24551ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:29:04zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:28:05zma_m24534ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:28:05zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:28:00zma_m24532ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:28:00zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:27:59zma_m24531ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:27:59zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:26:59zma_m24432ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:26:59zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:26:58zma_m24427ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:26:58zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:25:45zma_m24375ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:25:45zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:23:51zma_m24282ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:23:51zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:23:48zms_m24280ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:23:48zms_m24280ERRUnable to connect to monitor id 2 for streamingzm_stream.cpp48
2020-01-22 16:23:48zms_m24280ERRUnable to connect to zmc process for monitor 2zms.cpp259
2020-01-22 16:23:46zma_m24276ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:23:46zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:23:45zma_m24275ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:23:45zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:22:45zma_m24213ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:22:45zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:22:44zma_m24212ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:22:44zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 16:22:11web_js883ERRUncaught RangeError: Maximum call stack size exceededzm/tools/mootools/mootools-core.js1
2020-01-22 16:21:54zma_m24150ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 16:21:54zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:48:33zma_m23548ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:48:33zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:47:29zma_m23525ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 14:47:29zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:47:24zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:47:23zma_m23523ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 14:47:22zmwatch976ERRMemory map file '/dev/shm/zm.mmap.2' should have been 1160 but was instead 0zmwatch.pl
2020-01-22 14:47:22zma_m23522ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 14:47:22zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:47:18zma_m23514ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:47:18zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:47:13zma_m23513ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:47:13zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:47:12zma_m23512ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:47:12zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:46:03zma_m23493ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:46:03zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:46:02zma_m23492ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:46:02zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:45:01zma_m23471ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:45:01zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:44:07zma_m23451ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 14:44:07zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:44:02zma_m23449ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 14:44:02zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:44:01zma_m23448ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 14:44:01zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:44:00zmwatch976ERRMemory map file '/dev/shm/zm.mmap.2' should have been 1160 but was instead 0zmwatch.pl
2020-01-22 14:43:56zma_m23440ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:43:56zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:43:51zma_m23439ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:43:51zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:43:50zma_m23438ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:43:50zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:42:41zma_m23423ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:42:41zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:42:40zma_m23422ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:42:40zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 14:41:50zma_m23405ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 14:41:50zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:48:48zma_m21793ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:48:48zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:48:47zma_m21792ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:48:47zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:47:47zma_m21774ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:47:47zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:46:53zma_m21753ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 09:46:53zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:46:48zma_m21752ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 09:46:48zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:46:46zmwatch976ERRMemory map file '/dev/shm/zm.mmap.2' should have been 1160 but was instead 0zmwatch.pl
2020-01-22 09:46:46zma_m21751ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 09:46:46zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:46:42zma_m21743ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:46:42zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:46:37zma_m21742ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:46:37zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:46:36zma_m21741ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:46:36zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:45:37zma_m21726ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:45:37zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:45:36zma_m21725ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:45:36zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:44:25zma_m21708ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:44:25zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:43:31zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:43:31zma_m21687ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 09:43:26zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:43:26zma_m21686ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 09:43:25zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:43:25zma_m21685ERRShared data not initialised by capture daemon for monitor WyzePanzm_monitor.cpp498
2020-01-22 09:43:24zmwatch976ERRMemory map file '/dev/shm/zm.mmap.2' should have been 1160 but was instead 0zmwatch.pl
2020-01-22 09:43:20zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:43:20zma_m21677ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:43:15zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:43:15zma_m21676ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:43:14zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:43:14zma_m21673ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:42:05zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:42:05zma_m21655ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 09:42:04zmdc909ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 09:42:04zma_m21654ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 07:50:05zmdc909ERR'zma -m 1' exited abnormally, exit status 255zmdc.pl
2020-01-22 07:50:05zma_m1943ERRShared data not initialised by capture daemon for monitor RaspPizm_monitor.cpp498
2020-01-22 07:44:40zmdc861ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 07:44:40zma_m220534ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 07:44:39zmdc861ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 07:44:39zma_m220533ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 07:43:28zmdc861ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 07:43:28zma_m220514ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 07:41:27web_js20394ERRUncaught RangeError: Maximum call stack size exceededzm/tools/mootools/mootools-core.js1
2020-01-22 07:21:49zmdc861ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 07:21:49zma_m220236ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 07:21:48zmdc861ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
2020-01-22 07:21:48zma_m220235ERRGot empty memory map file size 0, is the zmc process for this monitor running?zm_monitor.cpp574
2020-01-22 07:20:48zmdc861ERR'zma -m 2' exited abnormally, exit status 255zmdc.pl
Most Common ones are:
Got empty memory map file size 0, is the zmc process for this monitor running?    zm_monitor.cpp    574
Shared data not initialised by capture daemon for monitor WyzePan    zm_monitor.cpp    498
When this occurs the camera is getting disabled for a several minutes and then works again and after some times the errors occurs again.
I have two cameras running.  The camera that is having difficulty was running on record, just switched it to mocord.  Other camera seems fine but is on modetect. Both cameras seem to be fine.
Re: Lots of errors. Camera feed being shutdown/restarted.
those errors are zma complaining that zmc isn't running.
So why isn't zmc running?
What is your Options -> System -> WATCH_MAX_DELAY ? Might have to be higher. Mine is at 45.
johnnyfive
I think zmc is running...
Not sure what is causing this error. It seems like it records for a few hours and then this type of error occurs and then resets I guess cause recording does restart after a few minutes. So my timeline has a few blank spots, which I am trying not to have.
Max delay is at 45 as well. I assume that's default.
