Page 1 of 1
Upgrade from 1.30.4?
Posted: Thu Jan 23, 2020 5:59 pm
by SkippyDo
I imagine that this is a long-shot but figured I'd ask it anyway: Is it possible (within reason) to upgrade to 1.34.x from 1.30.4?
I will be doing an upgrade (rather than fresh install) of Buster. Just too many configuration/modifications to start from scratch.
Re: Upgrade from 1.30.4?
Posted: Thu Jan 23, 2020 6:31 pm
by bbunge
You should be ok. Recommend you take a dump of the zm database first and run the upgrade from a terminal.
Posted: Thu Jan 23, 2020 9:32 pm
by SkippyDo
Would following these instructions be all that's necessary?
https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo
Posted: Thu Jan 23, 2020 11:45 pm
by bbunge
Not exactly. You will need to
sudo systemctl stop zoneminder
edit the sources.list
sudo nano /etc/apt/sources.list
Remove the entry for the 1.30 version. Likely the last line in the file
Add the following line to the end of the file
deb
https://zmrepo.zoneminder.com/debian/release-1.34 buster/
CTRL+o then [Enter] to save
CTRL+x to exit
Install the following and retrieve the key from the repo
sudo apt install apt-transport-https gnupg
wget -O -
https://zmrepo.zoneminder.com/debian/ar ... eyring.gpg | sudo apt-key add -
Important - Make sure the above "wget" process completes without error! If it does not complete you will not get the most recent Zoneminder version this procedure is written for.
sudo apt update
Then
sudo apt upgrade
