Probably an easy fix for this but I'm new at this so...well... here we go
I got to see the camera in ZM v1.32.x but couldn't get ZMninja to connect due to problems with the API so I did a fresh install of v1.33.x and *pooof* camera gone. Upgraded to 1.34 and same problem. Using an Raspi 4b 4GB ram and current ZM is 1.34.0 (upgraded using viewtopic.php?f=40&t=28969#p113415)
The camera is an PTZ ATFMI from aliexpress (used onvif manager app to get the url and set it up with libvlc)
It says capturing but when I click the camera it is blanc
Can't see Camera after update
Re: Can't see Camera after update
Easy enough to reflash Buster Lite on the SD card and start over. I am currently having great success with LEMP on my pi 3b+ and Zoneminder 1.34.0. Instructions on the WIKI.
Zoneminder needs the resolution to be spot on. I use VLC to check the camera settings.
