Hello!
I'm testing the possibillità to use the LOW Stream of my cam and then, in case of motion, register on the high resolution stream.
Until here all ok, I've this settings:
LOW-CAM: Modect
HIGH-CAM: Nodect - Linked to LOW-CAM
So, if something is detected on the LOW-CAM, the HIGH cam gets triggered and starts to record.
BTW I've noticed that LOG-CAM stream is recorded as well, so I have twice the same stream.
It's possible to register ONLY on the HIGH-CAM?
Then, it's possible to increare the pre- and post- seconds to have more registered time? (this seems more dificult due it's trivggered from another cam AFAYK).
Thanks!
Simon
Linked Monitors - Both cam must record?
Re: Linked Monitors - Both cam must record?
Any help?
In addition, I've noticed that on my two ESCAM G02 (http://www.escam.cn/product/showproduct.php?id=58) the test to use double streams linked to register doesn't work well.
Cold it be possible due the camera model?
Thanks,
Simon
Thanks,
Simon
ON the low res camera Monitor->Storage tab, set it to not store jpegs and nothing for Video Writer. db events will still be created, but files won't be stored on disk.
Thanks @iconnor for the help. Modify applied, I'll check the results.
Based on your experience, do you have ideas about the problem on the double stream on the cam?
Thanks, Simon
Thanks, Simon
Could be. I don't have any experience with that cam.
However I have seen lots of cams that can't handle multiple streams at the same time. YMMV
Okie, thanks for the help!
Maybe you could then suggest something good?
viewtopic.php?f=10&t=29040
Thanks for all!
Simon
Thanks for all!
Simon
