I have another problem. I hope this last one...
When the ZoneMinder service is started, I get a message that the launch was not executed. But the amazing thing is that Zonminder is recording and providing a live stream!
Does anyone know of this problem and can give me a tip for the solution?
Olaf
I receive the following information via Journal -f:
Feb 03 09:28:11 S2018Z620N001 systemd[1]: Starting ZoneMinder CCTV recording and surveillance system...
Feb 03 09:28:11 S2018Z620N001 sudo[6985]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/true
Feb 03 09:28:11 S2018Z620N001 sudo[6985]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Feb 03 09:28:11 S2018Z620N001 sudo[6985]: pam_unix(sudo:session): session closed for user www-data
Feb 03 09:28:11 S2018Z620N001 sudo[6987]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl check
Feb 03 09:28:11 S2018Z620N001 sudo[6987]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Feb 03 09:28:11 S2018Z620N001 sudo[6987]: pam_unix(sudo:session): session closed for user www-data
Feb 03 09:28:11 S2018Z620N001 systemd[1]: zoneminder.service: Control process exited, code=exited, status=1/FAILURE
Feb 03 09:28:11 S2018Z620N001 systemd[1]: zoneminder.service: Failed with result 'exit-code'.
Feb 03 09:28:11 S2018Z620N001 systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Journal -xe provides the following information:
-- The job identifier is 3784.
-- Subject: A start job for unit zoneminder.service has begun execution
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- A start job for unit zoneminder.service has begun execution.
-- The job identifier is 3851.
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit zoneminder.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
-- Subject: Unit failed
-- The unit zoneminder.service has entered the 'failed' state with result 'exit-code'.
-- Subject: A start job for unit zoneminder.service has failed
-- A start job for unit zoneminder.service has finished with a failure.
