No Stream or event feed
SomeGuy
Post by SomeGuy »
After getting some ssl problems sorted out I am able to log into my server with zmNinja. It shows the monitor status and event logs but I cannot view a stream or recorded video. The errors I seem to be getting is (oldest first, newest last).
AM INFO CACHE: error with http get [object Object]
AM INFO multi server list loading error
AM DEBUG reporting status of monitors from multi server
AM DEBUG cache_or_http error: [object Object]
AM DEBUG ***inside native HTTP error for url:https:mydomain.com/zm/api/servers.json?&token=<removed>
AM DEBUG ** Native intercept: Got 401, going to try logging in
This works in a browser and the getVersion.json request works n the browser. I am trying to log in with Android 6 and the app came from google play.
Unless it is just the way the errors are written is the app trying to use http and not https?
asker
Re: No Stream or event feed
Post by asker »
The logs you posted here are not (edited: rather, may not be) related to the streaming error. Have you made sure none of these apply?
1. Have you tried the free desktop app - does it work there? (If not, its very likely a network/setup issue)
2. FAQs:
https://zmninja.readthedocs.io/en/lates ... ing-issues
https://zmninja.readthedocs.io/en/lates ... ng-related
Please read before posting:
ES docs
zmNinja docs
