Hi
Running 1.34.1. I set up a filter to move events from fast storage to slower, compressed storage when the former is near capacity. It seems to work, but I can't play back events after they are moved and something seems to be wrong with the dates also:
The right dates should probably be 02/09 21:51:18 + duration instead.
Suggestions?
Mvh.
Torkil
Moving events with filter between storages doesn't quite work
Re: Moving events with filter between storages doesn't quite work
The actual files are here, on the slow storage:
2020-02-07 seems like the proper time stamp also, as 02/09 is way to young to be among the events to be archived.
[root@zm zoneminder]# find /zoneminder | grep 37919
/zoneminder/4/2020-02-07/37919
/zoneminder/4/2020-02-07/37919/00001-capture.jpg
/zoneminder/4/2020-02-07/37919/snapshot.jpg
/zoneminder/4/2020-02-07/37919/objects.json
/zoneminder/4/2020-02-07/37919/alarm.jpg
/zoneminder/4/2020-02-07/37919/00008-capture.jpg
/zoneminder/4/2020-02-07/37919/objdetect.jpg
/zoneminder/4/2020-02-07/37919/37919-video.mp4
/zoneminder/4/2020-02-07/37919/snapshot-400x226.jpg
Filter:
- Screenshot from 2020-02-10 10-24-30.png (77.44 KiB) Viewed 7095 times
I think zmupdate.pl is doing something bad. Turn it off. I will have to figure out what it is doing.
I'm not sure I understand this. I can't find anything about zmupdate.pl in the settings and I believed it was a script that was run manually when upgrading?
I'll be happy to provide debug information.
Thanks,
Torkil
Speaking of which, I'm holding back on updating to 1.34.2.
Mvh.
Torkil
Sorry I mistyped. zmaudit.pl is what I meant.
Go to Options -> System -> RUN_AUDIT. UNcheck it, click save, restart zoneminder.
