Upgrade Ubuntu 18.04
snicker83
Post by snicker83 »
Trying to upgrade from 1.32 to 1.34 running on Ubuntu 18.04
I cannot get passed insecure repository error
I have tried everything thing that I can find to get around condition
for example but not limited to
--allow-unauthenticated
--allow-insecure-repositories
I have added it to the sources.list all to no avail
any help would be appreciated.
Re: Upgrade Ubuntu 18.04
You need to remove the old Zoneminder repository and add the one for 1.34. Then run. The apt upgrade.
sudo add-apt-repository --remove ppa:iconnor/zoneminder-1.32
then
sudo add-apt-repository ppa:iconnor/zoneminder-1.34
snicker83
Post by snicker83 »
Thank you very much. worked like a charm.
I thought I had to remove 1.32 post upgrade.
Thanks again!
