Montage Review Calendar
cobash
Post by cobash »
Hi!
Has anyone run into a problem when trying to select a date range? The first date box works as expected giving me access to all of the months and days. The second box for the ending range only give me access to the last week. (See Picture Below) I am running Fedora 31, Zoneminder 1.34.2
Thanks!
cobash
Re: Montage Review Calendar
Post by cobash »
Forgot to mention I tried this in IE, Chrome, and Firefox. I can manually edit the url and put in a different date and that works fine. Just not the clickable calendar.
Thanks!
The second calendar won't go before the first one. So if the start calendar is set to Feb 1st, then the second will not go lower than Feb 1st.
cobash
Post by cobash »
I understand and that's the way it used to work. But in the picture it is only going back 1 week. I have the first date set to February 1st and the second date is only letting me go back one week from the current date. In my case when I tested it on the 21st and it is only letting me select as far back as the 14th.
confirmed. Will fix for 1.34.5
cobash
Post by cobash »
Many thanks!!
